#1 | |
l33t3st Asshole
Drives: MY07 Yaris Liftback Join Date: Nov 2006
make a stout mildly high compression motor (9.5:1) that makes decent power off boost then slap on a properly sized turbo 16g TD05 for example. make about 275whp have full boost by 3500 rpm and be golden. i said enough gases to warrant the sequential part of it. how often when in the "twisties" are you below 3k RPM? |
#2 | |
![]() ![]() ![]() Drives: bone f*ing stock Join Date: Dec 2008
I'm not going to argue with you as you seem to be stubborn as a mule on your opinion and apparently yours is the only one that counts. No one should ever do anything that is a viable solution everyone must conform.
#3 | |
l33t3st Asshole
I'm just waiting for someone to actually come up with a viable solution that is better then the one presented above.feel free to do so. I'll wait here why you try and figure out how to fit two turbos in a yaris...... ![]() haha, being different simply to be different is as bad if not worse then conforming to a well thought out performance setup that will be simple to setup/maintain and will make power. then again it is up to you, i'm merely on the other side of the internets voicing my mule of an opinion. :) |
| Turbo from Starlet on Yaris? | Adamantite | Performance Modifications | 15 | 09-22-2006 05:42 AM |
| Vitz Rs turbo vs U.S. Yaris add turbo? | weaponrcamry | Performance Modifications | 18 | 08-09-2006 08:45 PM |
