![]() Drives: Yaris Liftback 2008 Join Date: Mar 2009
Geez what a series of posts. It says 87 octane is recommended because that's the octane rating the engine was designed to run on. The reason it says minimum required is because IF you need gas and 87 isn't available for whatever reason, you CAN run 89 or 92; it will run on it. However there's no benefit other than not running out of gas. It will not increase power, mileage or improve the performance above what 87 octane does. It will leave more carbon residue in the engine if you continuously run the higher octane for the reasons stated in mine and other's previous posts.
If you want to run the higher octane stuff... it's your car, your money...fill it up with what you want. Just don't be surprised if your engine gunks up sooner than everybody else's. |
#2 | ||
![]() Drives: 2008 Yaris Sedan Join Date: Oct 2008
I spent half my life working in the labs and offices of the world largest gasoline and oil companies here in Houston, would love to read some facts and not opinions. Last edited by Ace; 04-27-2009 at 12:29 AM. |
#3 | |
Oh and keep in mind that the gas and oil companies WANT you spending more money on the higher octane fuels so they aren't about to tell you otherwise. Ask people who rebuild engines for a living; who service fuel and ignition systems; who make spark plugs, valves, rings, pistons. Ask the people who deal with the consequences of tens of thousands of miles of fuel usage in engines; they'll give you some "facts". If you're "sick and tired" then relieve your symptoms by doing some research yourself instead of demanding others do it for you. I stated what I know based on decades of experience with cars. If you don't like it or disagree with it; fine. Everybody is entitled to their opinion. Why don't you just fill your tank with 87; run it out, measure your gas mileage. Then fill up with 92 and see if you can tell any difference other than the cost. If you can't, then there's your "facts". But it's your car; spend your money on whatever grade fuel you want to. |
Chillin' out by the Bay
Drives: 2007 Yaris Liftback Join Date: Nov 2006
The Yaris was desgined to run on regular. Toyota states 87 octane as the minimun recommended fuel (nothing lower) in the owner's manual. Save the money for beverages and a turbo charger.
![]() Toyota designed the car with computer controls to enable it to run a relatively high compression on 87 octane by dynamically retarding ignition timing based on feedback from the knock sensor; further, they designed variable valve timing to scavenge exhaust from the cylinders more efficiently at higher rpm, lowering cylinder temperatures for the incoming charge. Without this technology, the engine would require higher octane fuel to avoid fuel detonation. Temperature, the by-product of compression, is the determinate factor for octane. The higher the compression, the higher the temperature and the higher the octane requirement. By old school standards, the Yaris is a very sophisiticated little engine. The Yaris' timing does not advance to account for higher octane fuel. Without higher compression, it would be pointless. It only retards from its set point to account for higher temperatures from engine load that would result in knock. The set point can be adjusted if this is out of spec or objectionable, but a little pinging under load especially in high ambient temperature is normal and is a sign that the engine is squeaking the last bit of energy out of the charge. Unfortunately, the Yaris doesn't dynamically raise its compression ratio without the assistance of forced induction. Using a higher grade fuel isn't required. Without higher compression, higher octance fuel in and of itself, won't improve the Yaris' peformance or extend its mpg to justify the expense; but, if you want to spend the cash....
Gettin' all the way down. Meteorite '07 HB STILL completely stock; but.... checkin' out da other ones to see what's what. |
| Fuel Economy | swng | Fuel Economy Forum | 2089 | 01-23-2015 06:41 PM |
| Economics of Price Gouging and Gas shortages | GeneW | General Yaris / Vitz Discussion | 1 | 10-31-2008 04:20 PM |
| Gas question | Meldav86 | General Yaris / Vitz Discussion | 23 | 09-28-2007 06:52 PM |
| A question about the gas thingee -- the place where you stick the nozzle. | petesimac | General Yaris / Vitz Discussion | 11 | 07-18-2007 08:23 PM |
| Free gas for any vehicle. | ketel0ne | General Yaris / Vitz Discussion | 4 | 09-19-2006 08:07 AM |
