Old 04-28-2009, 10:04 AM   #1
Tamago
Tamago's Avatar
Drives: UZJ100
Originally Posted by 1stToyota View Post
They over-adjusted your brake shoes. Now you're probably getting some excessive drag. Could be nice for your fuel economy and heat buildup. Not.
how do you know they over tightened it? just because it's now properly adjusted?
dont' feed the noob misinformation.
Old 04-28-2009, 10:25 AM   #2
1stToyota
1stToyota's Avatar
Misinformation? LMAO!
the emergency parking brake is very hard to lift up
Shoes aren't adjusted properly.
Go "properly adjust" yours until you almost can't lift your handbrake enough to get it to click once or twice...yeah, got it too tight didn't you?
1997 Lincoln Town Car - SOLD
2008 Scion xD
(w/ automatic) - SOLD
2008 Yaris HB - SOLD
Old 04-28-2009, 10:28 AM   #3
Tamago
Tamago's Avatar
Drives: UZJ100
Go "properly adjust" yours until you almost can't lift your handbrake any more...yeah, got it too tight didn't you?
maybe i have a stronger arm than you...
adjust the drums til they drag (no resistance, you can just hear them) , then back off the cable adjustment half a turn.
if you can't pull the e-brake handle up enough to keep the car from moving (be it 1 click or 10) then you need to start doing arm excercises.
carrot top jack up one of your rear wheels, and with the e-brake OFF, see if the wheel spins freely with no drag or noise.
Old 04-28-2009, 10:37 AM   #4
1stToyota
1stToyota's Avatar
Or if car still rolls, it's not an adjustment problem...could be problem with shoes or drums.
When I replace brakes, I start by using of a drum gauge, and then adjust until I can just start to hear scraping. I don't run across too many stretched cables. 1 click is too tight, 10 clicks is a Ford Tempo in serious need of a brake job.
2008 Scion xD
Toyota Maintenance at Dealership? fmicle DIY / Maintenance / Service 18 03-17-2012 11:27 AM
Response from Toyota on my special order drdavidr4u New YARIS Purchase Forum 14 04-27-2010 08:59 PM
Response from Toyota Driver New YARIS Purchase Forum 22 09-04-2006 07:44 PM
Toyota Delays Buckethead General Yaris / Vitz Discussion 3 08-26-2006 03:16 AM
Toyota Yaris to Sponsor FOX's "Prison Break" YarisBueller General Yaris / Vitz Discussion 0 04-30-2006 08:01 PM
