Old 12-23-2009, 08:04 PM   #1
UTVitz
UTVitz's Avatar
Drives: Black Vitz Liftback
I was lucky enough to have another vehicle to drive, but the dealer had my car two days before the work was completed. I did tell them to not rush it as I really hated having the dash taken apart and was worried about dash rattles. So far three months later everything seems well screwed together again. So glad I had it done-I really thought the musty smell after using the a/c was something I had to live with-nope.
UTVitz is offline   Reply With Quote
Old 12-23-2009, 10:25 PM   #2
adamschneider
adamschneider's Avatar
Drives: Bayou Blue 2dr, AT
I finally got out of there at 6:00, as the dealership was closing... and found that they put my console back together wrong!!!! They switched around the heat and blower controls, and now neither one feels exactly right. The whole thing doesn't look flush either. I am so pissed off.
I guess I should have let them keep it and "not rush it." God damn it.
adamschneider is offline   Reply With Quote
Old 12-28-2009, 06:32 AM   #3
unclenefeesa
Da Uncle
Drives: 2008 Toyota Yaris Sedan
I called the dealer last week to ask about the odor from the AC. From the quick reply they gave over the phone I could tell this was a frequent problem with them.
I didn't mention the TSB (I am not in the US) but all they suggested is to take an appointment (earliest available is after mid January) and they would clean the AC with some chemical. It would take more than 3 hours to finish and would cost me 75 USD. what a rip off.
I will call them back later this week ans ask why this is not covered by warranty. I mean the car is still under warranty and the AC is not functioning properly right?
I bought an air system cleaning can. it comes with long tube. i used the tube and sprayed the inside of the AC for 5 to 6 seconds. I haven't used the AC since then, but the car smells extremely clean and fresh that it some times gives me and my wife a headache.
unclenefeesa is offline   Reply With Quote
Old 12-29-2009, 04:55 AM   #4
unclenefeesa
Da Uncle
Well, the air system cleaning can certainly gave my car a clean fresh smell but it didn't solve the problem. The smell comes on as soon as I turn the fan on (both on hot and cold).
Old 12-28-2009, 11:45 AM   #5
UTVitz
UTVitz's Avatar
Have the dealer run your VIN to see if it falls under the TSB for a/c evap. replacement. The musty smell comes from the metals used to make the evap. core-it's defective. But once you run out of warranty you're out of luck to get toyota to cover it-and it's not a safety item, hence no recall on this problem.
Old 12-29-2009, 04:56 AM   #6
unclenefeesa
Da Uncle
I don't live in USA. the TSB we have says US Market only. the Dealer doesn't have to honor this TSB, unless I can find a TSB that does not say US Only.
Old 12-28-2009, 12:22 PM   #7
swidd
Drives: Yaris HB
Not a safety problem? Is it healthy to breath in these gases, especially if the A/C gas starts leaking?
Old 12-28-2009, 12:58 PM   #8
Yaris Hilton
Half a Bubble Off Plumb
Yaris Hilton's Avatar
Drives: 2009 Yaris Sedan
Smile
The AC refrigerant gas is the same stuff used to propel the medical inhalants people with asthma and COPD use. The FDA says they're safe, in the small quantities they use. If you have a big enough leak to be breathing much of the gas, your AC's going to quit working shortly.
Old 12-28-2009, 12:55 PM   #9
YarisSedan
Drives: 08 Yaris Sedan
I like how they always start every TSB "some customers may experience" when in actuality usually all customers experience the problem but have not complained about it yet or are just afraid to bring their car into the dealer cause they are past the warrenty period.
Old 03-23-2010, 01:07 AM   #10
bladesmith6
Drives: 2007 yaris HB
Has anyone attempted to do this repair themselves? The reason I ask is i called the local dealership and because my car is JUST out of the warranty they would not cover it, not to mention the whole "we have to test to find out if thats the problem" routine. I know what the problem is and hate going to the dealership at all especially multiple times because of stupid requirements. I guess I would need to know what all the correct parts #'s are so I could have everything ahead of time.
bladesmith6 is offline   Reply With Quote
Old 03-23-2010, 09:06 AM   #11
I have pulled Crashy's AC system apart for curiosity sake. Replacing the affected parts requires taking the entire dash apart and removing the airbox assembly to get at the condenser. It is quite doable, but takes a bit of time. The nice thing about doing it yourself is that you'll be more careful not to scratch up the dash parts on your own car.
As for the parts required, if you look at the pdf of the TSB (which is posted), it lists the parts that get replaced.
Old 03-27-2010, 11:30 AM   #12
bronsin
bronsin's Avatar
Here is a picture of stuff you can get to fix stinky climate control systems.
Old 06-17-2011, 10:55 AM   #13
ROCKLANDTOYOTA
JOE GIRTH
Drives: YARIS 3DOOR
WTF is that crap on your keyboard???? EEEEWWWWWW
ROCKLANDTOYOTA is offline   Reply With Quote
Old 03-23-2010, 10:11 PM   #14
bladesmith6
ok well at least that gives me something to work with. Still have to go to a shop to recharge the system but it should still cost less than getting the whole thing done there. i hope.....
Old 03-24-2010, 09:36 AM   #15
swidd
Drives: Yaris HB
I just had the TSB about the exhaust/catalytic converter assembly replacement done. Sulfur/burning trash smell is gone! Burning oil smell introduced!
Last edited by swidd; 03-28-2010 at 07:07 PM. Reason: EDIT: it improved my MPG from steady average 37 to 39 on last tank!
Old 03-27-2010, 12:09 PM   #16
127.0.0.1
that should go away once it is cooked off
Old 03-24-2010, 09:41 AM   #17
bronsin
bronsin's Avatar
Its a really bad idea to run your AC on recirc for long periods of time. Frequently change to circulate fresh air. Mold or something gets in the internal components of the climate control system. It stinks to high heaven. My wife did that to her Camry and its hard to sit in the vehicle it stinks so bad.
Old 03-24-2010, 09:53 AM   #18
sbergman27
sbergman27's Avatar
Drives: 2008 Yaris Sedan
How would switching to 'fresh' prevent or remove the mold?
-Steve
sbergman27 is offline   Reply With Quote
Response from Toyota on my special order drdavidr4u New YARIS Purchase Forum 14 04-27-2010 09:59 PM
service at toyota THEDON DIY / Maintenance / Service 4 04-24-2009 02:45 PM
Does Toyota have a website for recording vehicle service? YarisOwnersDad DIY / Maintenance / Service 4 04-05-2009 12:42 AM
Funny Business at the Toyota Service Centre *MAD DOG* DIY / Maintenance / Service 10 01-10-2009 01:47 AM
Toyota Delays Buckethead General Yaris / Vitz Discussion 3 08-26-2006 04:16 AM
