Old 04-28-2009, 12:21 PM   #1
at3GG
at3GG's Avatar
Drives: 07 metmet LB
meaning if your exhaust gives you 5hp but you drive it exactly the same as before, theoretically your mpg should increase because you have more power pulling the same weight. However, most of us like to use the extra power that we get so it will basically cancel out any mpg gain. Think thats what he meant basically?
F5 CAI, MR axleback, MR Header, NST SSK.
Full Exhaust wrap, AT3 Custom SSK
Konig Heliums 15x6.5 Black
Tanabe Df210's
at3GG is offline   Reply With Quote
Old 04-28-2009, 12:32 PM   #2
marcus
toyota
marcus's Avatar
Drives: 2007 Yaris RS Blazed
got it thanks..it does make sense...its just there is a theory that back pressure allows the engine to reuse unburn fumes that stays on the enginedue to backpressure.to get a better gas mileage..???
Old 04-28-2009, 12:49 PM   #3
yaris-me
Learn to Relax
Drives: 2007, Meteorite, LB
You missed the point about velocity and scavenging by MadMax. To reuse exhaust gas would be a valve timing design. That helps to keep the temperature lower to allow for a leaner burn.
Reducing back pressure can get you a slight increase in gas mileage, but there is a point of diminishing return. That is what we don't know. For that you would need to consult an engineering expert.
Old 05-03-2009, 01:09 AM   #4
GeneW
Drives: 2008 Yaris
That's what the EGR (Exhaust Gas Recirculation) is for. Changes the chemistry of the gas mixture. If memory serves correctly it was originally meant to allow leaner mixtures to be used without pinging.
Gene
Using DFCO to increase your MPG BailOut Fuel Economy Forum 216 08-30-2018 04:15 AM
42.04 MPG straight off the lot! bnther36 General Yaris / Vitz Discussion 25 05-17-2010 06:09 PM
My progression into hypermiling BailOut General Yaris / Vitz Discussion 8 10-13-2009 06:31 PM
Help me see 55 mpg! Loren Fuel Economy Forum 76 04-02-2009 04:23 PM
To accurately measure MPG when should I fill back up. mgthompson General Yaris / Vitz Discussion 17 03-30-2007 10:07 PM
