Old 04-28-2009, 12:49 PM   #14
yaris-me
Learn to Relax
Drives: 2007, Meteorite, LB
got it thanks..it does make sense...its just there is a theory that back pressure allows the engine to reuse unburn fumes that stays on the enginedue to backpressure.to get a better gas mileage..???
You missed the point about velocity and scavenging by MadMax. To reuse exhaust gas would be a valve timing design. That helps to keep the temperature lower to allow for a leaner burn.
Reducing back pressure can get you a slight increase in gas mileage, but there is a point of diminishing return. That is what we don't know. For that you would need to consult an engineering expert.
Using DFCO to increase your MPG BailOut Fuel Economy Forum 216 08-30-2018 04:15 AM
42.04 MPG straight off the lot! bnther36 General Yaris / Vitz Discussion 25 05-17-2010 06:09 PM
My progression into hypermiling BailOut General Yaris / Vitz Discussion 8 10-13-2009 06:31 PM
Help me see 55 mpg! Loren Fuel Economy Forum 76 04-02-2009 04:23 PM
To accurately measure MPG when should I fill back up. mgthompson General Yaris / Vitz Discussion 17 03-30-2007 10:07 PM
