Go Back   Toyota Yaris Forums - Ultimate Yaris Enthusiast Site > Second Generation Toyota Yaris Main Rooms > Regional Forums > Hawaii
Old 05-07-2009, 07:10 PM   #1
gwasabi
Drives: 07 Blazing Blue LB
Lol ^ there you go. Like I said I don't know shit about cars gotta listen to someone who knows.
I would figure you don't need slicks on our cars too little power. I would have to agree with you on running good tires but Peter seemed like he really wanted to use slicks.
Hmmm I just thought he'd spin out with stock tiresin the rear cause our rear is actually lighter than the front and you can feel it in the hatchback. Like when I go over bumps and stuff there is like Almost NO weight in the rear so I thought it'd be a bad idea but again, I never drag race, More into grip lol
Most Satisfying Crew
Serious Business...
MunkyWurks Garage - 8088488794
gwasabi is offline   Reply With Quote
Old 05-07-2009, 08:10 PM   #2
PETERPOOP
PETERPOOP's Avatar
Drives: 08 white liftback
that says it all
you are seriously retarded. did you get this from my one statement of saying i'd run slicks in the front and stocks in the back? yah, i REALLY really wanted to use slicks so bad. oh boy i do....
Old 05-07-2009, 08:16 PM   #3
battleversiontc
battleversiontc's Avatar
Drives: 08 vip yaris
drag racing you dont have to worry about bumps and stuff but you do have to worry about lift that what will cause a car to lose traction on fwd car but your not going more then 125 so you dont need to worry about that. grip racing you do have to worry about loosing traction in the rear but thats also compansated on a properly set up suspension comes down to dampening control chassis flex chamber rebound tires toe setting downforce wing adjustment and braking force all come into play about grip racing. drag racing the more zerod out the alignment the less resistence you have the more aerodynamically the car is the better and down force or position of the wing is all key to keeping the rear planted at higher speeds. as for drag racing you want as much weight as possible on the front anyways to keep the front down and traction there
08 junction produce belta almost done and ready for paint
06 junction produce tc 604 bhp 445tq ddriven still trying for 700+hp
90 crx sir ls vtec turbo 755 hp
mecp masters certified
battleversiontc is offline   Reply With Quote
Old 05-07-2009, 08:19 PM   #4
PETERPOOP
PETERPOOP's Avatar
i can't believe they are making a 1/8 track and not a 1/4 track. ahhh
evan, where you located? i want to swing by one day and check out your belta
Old 05-07-2009, 08:23 PM   #5
battleversiontc
im actually in kaimuki but the car is actually in kailua at my buddys house since i have to many friends coming to my house to check out my projects
Old 05-07-2009, 08:24 PM   #6
PETERPOOP
PETERPOOP's Avatar
lol, ok nevermind then.
Old 05-07-2009, 08:45 PM   #7
battleversiontc
but ill let you know like two days in advance when the cruise is cause they go out your direction maybe you can meet up or something
Old 05-08-2009, 05:43 AM   #8
Taiyaki
アキバ製
Taiyaki's Avatar
Ho me too, I have never seen your car though.. hiding from me huh? haha jk
Anyways...excuse my "noobness"...how does the corolla TB (throttle body) work with the Yaris exactly? and do you have to worry about ECU and tuning?..or am I way off base here?
I hear it just drop in a good to go, but some people said to just swap the chip to get rid of the oscillation. idk yoshi done it, im sure he will give you the run down.
Old 05-08-2009, 05:54 AM   #9
Taiyaki
アキバ製
Taiyaki's Avatar
^I read that the grounding kit really helps, I was thinking about picking one up off ebay.
Old 05-08-2009, 06:22 AM   #10
battleversiontc
that car rarely goes out now shame thats why haha no more interior my tc sees more action
Old 05-08-2009, 03:42 PM   #11
gwasabi
I wouldn't think you'd feel anything on a grounding kit. I had a grounding kit on my g but no help at all....on the other hand it was FBC. oh well.
The throttle body is actually bigger than the stock one which lets more air into the car. Think of it like a beefed up version of a intake. More air means more combustion. Mo pauwa!
Your gonna have some side effects though. nothing you can't fix. I'll help you out with it.
Oscuillation is one
HIgh Cold Start Idle
CEL
These are the sideeffects but I have been able to fix all except the high cold start idle.
I'm actually looking for some 1zz injectors to play around with but the junk yarddoesn't seem to have any hahaha I might just have to buy em or look somewhere else
Serious Business...
Old 05-08-2009, 09:55 PM   #12
battleversiontc
grounding wires do alittle bit but you dont feel it um dont buy just make your own outta 8 ga wire thats all it is and plus to you can actually make em look clean i run a set on my yaris i even tied all the coil ground screws and ground it and it made some difference on accleration i think they made like 2 hp or something like that when they dyno'd it
pulled and rolled BrazdonW Cosmetic Modifications (Exterior/Interior) 30 05-06-2009 11:23 PM
