Old 04-28-2009, 05:09 PM   #1
Astroman
Modded Moderator
Astroman's Avatar
Originally Posted by schleppy View Post
So did anyone see any HP gains with just the light crank pulley (not underdriven), and the OEM WP and Alt pulleys?
Thanks!
Really, the lite pulley frees up HP from the crank that would otherwise be wasted moving a considerably heavier pulley. Seriously, you could use the stock pulley as a boat anchor (albeit on a very small personal boat, but still you get the idea.) Also a plus on the automatic is it helps resolve "gear hunting" up hills.
Old 05-01-2009, 03:29 AM   #2
eii
Rides canyon walls
eii's Avatar
Drives: 1988 RX7 FC 10th AE
Thanks!
I have JUST the light crank pulley and it made a world of a difference. I had the battery disconnected while I was working on the pulley and some electrical stuff so I guess it took the ECU a couple of day to 'learn' the new revs. Theres a definite increase in power all throughout the power range. I could only imagine the addition of the WP and ALT will increase power even more. Honestly just the difference you feel at idle and shifting is worth it, I just consider the HP a cool bonus.
The stock pulley is way heavier than the NST one. I was playing with the stock one earlier today and dropped it on my foot...OW...
I did notice on my auto sedan when going up a hill it didnt do that stupid gear hunting .
OEM Style Wing Spoiler | TRD Axle-Back Exhaust | Megan Lowering Springs (1.5 f/r) | Simota Carbon Charger Intake | Python 871XP Alarm System | Aluminum Sports Pedal | 17x7 +42mm Enkei J10 Black w/ Silver Lip | 205/40 Falken Ziex-912 | NST Lite Crank Pulley Red | 1ZZ-FE Throttle Body | AMK Racing Header
eii is offline   Reply With Quote
Old 05-09-2009, 08:30 PM   #3
Astroman
Modded Moderator
Astroman's Avatar
Nice! I'm glad to hear this also helped resolve your "gear hunting".
Old 05-11-2009, 06:47 AM   #4
d1nzfe
Drives: 1NZ-FE
Hi NST pulley users, I would like to know if you guys have this sign of wear and tear on your WP-lite pulley?
d1nzfe is offline   Reply With Quote
Old 05-11-2009, 03:40 PM   #5
NonStopTuning
This is typical and happens with all pulleys over time. Nothing to be concerned with, or worry about.
Good luck and have fun with all your projects!
MIKE @ NST
www.NonStopTuning.com
Old 05-12-2009, 10:43 AM   #6
d1nzfe
Drives: 1NZ-FE
does this mean we have to change it just like the stock one?]
anyone have issue with a worn one??
Old 05-12-2009, 11:13 AM   #7
NonStopTuning
MIKE @ NST
