I just added a note on my DIY in regards to cars with MT. TDB-1 PM'd me tonight. He attempted the two button method on his 09, and the on/off worked, but not the set. He inquired if there was anything different about a MT, and it turns out that the MT requires a second switch on the clutch for cruise.
The "Cruise Control Clutch Switch" is needed as well. This is a second clutch switch (there's already one called the "Clutch Start Switch"). The "Cruise Control Clutch Switch" connects to connector A29. Its part number is: 88280-14030 and it lists for ~$18. |
#3 | |
![]() ![]() ![]() ![]() Drives: 2009 Yaris Hatchback Join Date: Feb 2009
I ♥ Yaris
Drives: Black 08 LB MT & red 97 Miata Join Date: Oct 2008
Damn damn damn! I have an 08 MT. That's 2 strikes. My dream of $20 OEM CC is fading fast...
The trouble with the world is that the stupid are cocksure and the intelligent are full of doubt. - Bertrand Russell |
#5 | |
Yes, the clutch switch is just for MT, and it is still needed with the OEM stalk. It keeps the car from over revving if you press the clutch while in cruise mode. |
![]() Drives: 09 3-door 5speed Join Date: May 2009
cruise
Ok I just finished up my 2 button cruise setup on my 09 3 door 5speed. I did everything as per the DIY and it works great!!!! I had to jump the clutch switch for the test until I get the correct switch. This works just don't step on the clutch while on cruise or the engine could over rev. I got my switches at Radio Shack for $2.69 each and they look identical to the ones in the DIY. I used 2- 330 ohm resisters also from Radio Shack that cost $.99 for a 5 pack. This is the best thing I did to the car since I got it. THANKS to all who figured this was possible
| DIY - 2009 Cruise Control for $10, without pulling the steering wheel and airbag | CTScott | DIY / Maintenance / Service | 307 | 04-04-2023 03:43 AM |
| DIY Cruise Control on 07-08 Yaris (step by step) | Vince87 | DIY / Maintenance / Service | 431 | 12-28-2020 01:37 AM |
| Cruise Control - Again! | CB900F2 | DIY / Maintenance / Service | 47 | 06-17-2010 06:29 PM |
| Cruise control vs MPG | YarisOwnersDad | Fuel Economy Forum | 15 | 05-29-2009 03:55 PM |
| Using Cruise control | Driver | General Yaris / Vitz Discussion | 14 | 11-09-2006 10:12 PM |
