Old 05-03-2009, 05:46 AM   #1
PETERPOOP
PETERPOOP's Avatar
Drives: 08 white liftback
Because it sounds like you are ready to stop at the putting on the stock airbox. I say get yourself some 1zz injectors!
well i am done for now. I am getting 12-12.1 AFR during WOT openloop. I will get larger injectors/tb when i get it tuned.
Old 05-03-2009, 02:49 AM   #2
LtNoogie
LtNoogie's Avatar
Drives: '08 Bayou Blue LB AT
As some of you know, I've been swapping in and out fuel injectors more often than some people change their underwear. The only way for me to get to injectors 3 and 4 is to take off the valve cover which, although not difficult, is kinda a PITA. So today, I took a hacksaw to the valve cover and removed that stupid little tang that keeps one from removing the fuel rail easily.
Old 05-03-2009, 11:42 AM   #3
Somehow I missed that Peterpoop fixed his lean condition. So who is still getting a lean condition?
Old 05-04-2009, 11:00 AM   #4
largeorangefont
Break'em off some.
largeorangefont's Avatar
Drives: 07 Yaris LB, 04 Cobra
I missed that too, But I have not been following this as closely as I was before.
Old 05-04-2009, 11:02 AM   #5
largeorangefont
Break'em off some.
Noogie,
You probably will never be able to fix the CELs at startup unless you can reflash the ECU to scale the larger injectors (which we cant currently do). You need injectors that are a little smaller to get rid of that. The car has a +/- 25% fuel correction, so you need injectors that flow no more than 25% more fuel than the stock units to avoid getting CELs.
10.5:1 is good, If you can get a fuel controler on there to lean it out a bit you will be in decent shape.
Old 05-03-2009, 03:43 PM   #6
gwasabi
Drives: 07 Blazing Blue LB
I'm guessing that the Yaris injectors are somewhere around 200-250cc injectors. from what I can see the 1zz is about 300-350cc. I believe the TC injectors are like 400cc or something. I remember reading a thread somewhere. so I think that 1zz injectors should be good to go for you. Check a junkyard and just pocket em. lol that's what we do in Hawaii.
Most Satisfying Crew
Serious Business...
MunkyWurks Garage - 8088488794
gwasabi is offline   Reply With Quote
Old 05-03-2009, 03:46 PM   #7
PETERPOOP
PETERPOOP's Avatar
we do? Maybe ghetto crackhead thieves!
Well when I put the stockairbox in, I was getting 12-12.1 AFR readings during WOT openloop. Only time I get into that number is during open loop. We all wish it could go into open loop sooner, but I don't think the blitz fuel controller controls that.
Old 05-03-2009, 03:48 PM   #8
gwasabi
they're making money off trash man that's kinda theiving themselves lol. I got seatbelts from a 1989 Corolla when I had my hachi. Just walked out with it in my hands all visible and everything. They never said anything.
Serious Business...
Old 05-03-2009, 06:53 PM   #9
fwiw, the trd s/c for the matrix/corolla was never meant to be used w/ the trd intake...it would void warranty otherwise since it would make the engine run lean. matrix/rolla guys use emanage to fix the a/f ratios to run intake, otherwise youre relagated to stock airbox and exhaust
Old 05-03-2009, 07:01 PM   #10
PETERPOOP
PETERPOOP's Avatar
sounds about right. however the guys using the CAI aren't having a problem with the AFR. Maybe their intakes aren't doing anything.....
Old 05-03-2009, 07:49 PM   #11
PETERPOOP
PETERPOOP's Avatar
youbelieve those bogus charts? ;)
Old 05-03-2009, 07:58 PM   #12
PETERPOOP
PETERPOOP's Avatar
But i'm not trying to sell you my product. I didn't think people actually believed those dyno charts company put out for intakes.
Old 05-04-2009, 02:04 AM   #13
No way the tC injectors are 400cc
Old 05-04-2009, 10:34 AM   #14
kurokoma-kun
Drives: 2007 Yaris HB
Congrats Long glad to hear you are on the right track...
unless you are still having bad dreams, in which a 50-foot-tall fuel injector uses his blue tape beam to battle the air intake monster for supremacy of the earth's AFR?
How do I cure a lean condition? LtNoogie Performance Modifications 101 03-21-2013 11:40 PM
RC Engineering injectors will not fit our engine with the current setup LtNoogie Performance Modifications 14 06-18-2009 03:38 AM
Spark plug diagnosis and lean condition camelll Forced Induction Forum 33 05-09-2009 12:48 AM
Can the Yaris handle 6psi with stock ECU, injectors and fuel pump? trini_per4mance Forced Induction Forum 19 05-06-2009 01:18 PM
