My R1 eats my Vitz!!
Drives: '07 Vitz Lifty, Stick Shift Join Date: May 2007
TDB-1, to jump the switch connector, you simply put a wire from one terminal to the other (the switch plug only has 2 terminals right)? You didn't put a fuse or anything in there just in case?
My Car Rules! |
![]() Drives: 09 3-door 5speed Join Date: May 2009
Correct, I actually used a small spade terminal and just pushed it into the connector. Just don't step on the clutch when using cruise!!!! I have not hit the clutch but think if you did it would rev the motor till the computer or rev limiter figures out what is happening.
![]() Drives: '10 Yaris 3 DR - Carmine Red Join Date: Jan 2010
This thread shows the details on the clutch switch connector:
http://www.yarisworld.com/forums/showthread.php?t=23510 |
| OEM foglight switch and leather wrap steering wheel | 808yarisLB | Cosmetic Modifications (Exterior/Interior) | 8 | 03-11-2009 12:05 AM |
| SCION SPORT STEERING WHEEL, RED, XA AND XB, 03 TO 06 | justoneyaris | Items for Sale by private party | 3 | 12-04-2008 06:30 PM |
| steering wheel setup | aucorium | Cosmetic Modifications (Exterior/Interior) | 0 | 07-24-2007 01:05 AM |
| How do you take off steering wheel | mrrock | Cosmetic Modifications (Exterior/Interior) | 3 | 12-05-2006 10:16 AM |
