Old 05-02-2009, 03:11 PM   #1
gwasabi
Drives: 07 Blazing Blue LB
So wait noog your running rich now?
Why don't you try the 1zz Fuel injectors instead?
Most Satisfying Crew
Serious Business...
MunkyWurks Garage - 8088488794
gwasabi is offline   Reply With Quote
Old 05-02-2009, 04:00 PM   #2
LtNoogie
LtNoogie's Avatar
Drives: '08 Bayou Blue LB AT
I'm looking for some right now, cheap. I figured a 1.8L Corolla should be using slightly larger injectors than the 1.5L Yaris but not as much as a 2.4L tC.
The alternative is a boost compensating fuel regulator. I'm getting more fuel than I can handle (CELs) when I'm at low RPMs and am still running rich at WOT. I may want to regulate my fuel pressure down a bit to cure the rich non-boost situations and let the regulator bump up the pressure one pound for each pound of boost.
It's a never-ending disease, this wanting to tweak the car. And I haven't even started collecting the parts for water/meth injection yet.
How do I cure a lean condition? LtNoogie Performance Modifications 101 03-21-2013 11:40 PM
RC Engineering injectors will not fit our engine with the current setup LtNoogie Performance Modifications 14 06-18-2009 03:38 AM
Spark plug diagnosis and lean condition camelll Forced Induction Forum 33 05-09-2009 12:48 AM
Can the Yaris handle 6psi with stock ECU, injectors and fuel pump? trini_per4mance Forced Induction Forum 19 05-06-2009 01:18 PM
