Somehow I missed that Peterpoop fixed his lean condition. So who is still getting a lean condition?
Break'em off some.
Break'em off some.
Noogie,
You probably will never be able to fix the CELs at startup unless you can reflash the ECU to scale the larger injectors (which we cant currently do). You need injectors that are a little smaller to get rid of that. The car has a +/- 25% fuel correction, so you need injectors that flow no more than 25% more fuel than the stock units to avoid getting CELs. 10.5:1 is good, If you can get a fuel controler on there to lean it out a bit you will be in decent shape. |
| How do I cure a lean condition? | LtNoogie | Performance Modifications | 101 | 03-21-2013 11:40 PM |
| RC Engineering injectors will not fit our engine with the current setup | LtNoogie | Performance Modifications | 14 | 06-18-2009 03:38 AM |
| Spark plug diagnosis and lean condition | camelll | Forced Induction Forum | 33 | 05-09-2009 12:48 AM |
| Can the Yaris handle 6psi with stock ECU, injectors and fuel pump? | trini_per4mance | Forced Induction Forum | 19 | 05-06-2009 01:18 PM |
