Old 05-03-2009, 02:03 PM   #1
nickhjort
My R1 eats my Vitz!!
nickhjort's Avatar
Drives: '07 Vitz Lifty, Stick Shift
I see, I see. One other quick question. If I don't have all the wiring for this from the ECM, do you think I will have to do anything to get the brake switch to work, or will it already be programmed to turn off the cruise control when I hit the break? And I didn't see the plug for the clutch switch near where the switch goes...will I have to wire that once I buy the actual switch and take the jumper out?
My Car Rules!
nickhjort is offline   Reply With Quote
Old 05-03-2009, 02:54 PM   #2
If your Yaris has the brake switch, then your OK, as there is only one.
For the clutch switch, if this works, then you'll have to snake a wire from the under hood fuse box to the clutch switch and wire it yourself.
DIY Cruise Control on 07-08 Yaris (step by step) Vince87 DIY / Maintenance / Service 431 12-28-2020 01:37 AM
Cruise Control - Again! CB900F2 DIY / Maintenance / Service 47 06-17-2010 06:29 PM
Cruise control vs MPG YarisOwnersDad Fuel Economy Forum 15 05-29-2009 03:55 PM
