Old 05-03-2009, 06:53 PM   #1
fwiw, the trd s/c for the matrix/corolla was never meant to be used w/ the trd intake...it would void warranty otherwise since it would make the engine run lean. matrix/rolla guys use emanage to fix the a/f ratios to run intake, otherwise youre relagated to stock airbox and exhaust
Old 05-03-2009, 07:01 PM   #2
PETERPOOP
PETERPOOP's Avatar
Drives: 08 white liftback
sounds about right. however the guys using the CAI aren't having a problem with the AFR. Maybe their intakes aren't doing anything.....
How do I cure a lean condition? LtNoogie Performance Modifications 101 03-21-2013 11:40 PM
RC Engineering injectors will not fit our engine with the current setup LtNoogie Performance Modifications 14 06-18-2009 03:38 AM
Spark plug diagnosis and lean condition camelll Forced Induction Forum 33 05-09-2009 12:48 AM
Can the Yaris handle 6psi with stock ECU, injectors and fuel pump? trini_per4mance Forced Induction Forum 19 05-06-2009 01:18 PM
