Old 05-04-2009, 11:46 AM   #1
mrbond
mrbond's Avatar
I'm definitely missing something. Where do the additional 2 wires from D3 go? I mean, with the switch method for models other than the 09, it seems like you don't need to use D3. But since I'm going to be using the stalk, I need to use D3.
- A Toyota Yaris
- A whut Yaris?
Old 05-04-2009, 12:22 PM   #2
The connector above is D3. If you use the switch method for 08, then you go straight from the ECM to the switches.
For the stalk method the wire from pin 40 of the ECM goes where the blue wire is above in D3. Where the brown wire is in D3, you will run a wire from that position to a ground point.
Old 05-04-2009, 12:42 PM   #3
nickhjort
My R1 eats my Vitz!!
nickhjort's Avatar
Drives: '07 Vitz Lifty, Stick Shift
PCB for 07 Hatchback
Here's those pics CTScott...hope they are good enough. If you need more I can take more tomorrow. I'm heading to work right now...
Sorry there's so many on this post, but I figured the more the better :) Let me know what you think. Like I said before, I feel pretty confident in my basic electrical abilities. I can solder to PCB's and all that fun stuff. I would rather not switch the switches around (since I just got them all done and looking good), but however I can get that light to light up I'll do it. Oh and also I have a 12V LED in there right now, only cause I had a bunch laying around. Let me know if I need a different voltage LED too. Thanks again.
And I hope all this stuff is helping other people want to do this mod. I've spent less than $10 so far. $500 or $10...no brainer
My Car Rules!
nickhjort is offline   Reply With Quote
Old 05-04-2009, 12:50 PM   #4
33OH
Drives: '08 Yaris
Definitely watching. I hate doing electrical work, so waiting on another dummy like me to attempt it. Or a nice DIY wrote up.
Great work so far guys.
Old 05-04-2009, 01:03 PM   #5
nickhjort
nickhjort's Avatar
Well I'm your dummy ryank!
And Thanks for scratching around CTScott. My car is all put back together for now, so I won't get a chance to work on it again till this weekend. In the meantime, lemme know what you think about the LED. Thanks a million!
My Car Rules!
DIY - 2009 Cruise Control for $10, without pulling the steering wheel and airbag CTScott DIY / Maintenance / Service 307 04-04-2023 03:43 AM
DIY Cruise Control on 07-08 Yaris (step by step) Vince87 DIY / Maintenance / Service 431 12-28-2020 01:37 AM
Cruise Control - Again! CB900F2 DIY / Maintenance / Service 47 06-17-2010 06:29 PM
Cruise control vs MPG YarisOwnersDad Fuel Economy Forum 15 05-29-2009 03:55 PM
Using Cruise control Driver General Yaris / Vitz Discussion 14 11-09-2006 10:12 PM
