Old 05-04-2009, 05:39 PM   #1
MGargano
Drives: 2009 Yaris Hatchback
If I'm using the OEM stalk method on an '09, is it just plug & play? I know I need the cruise control clutch switch but I'm wondering if there are any other wires/connections I need to make to get it working.
Old 05-04-2009, 05:57 PM   #2
No - That's it. For an 09 AT, it's just mount and plug in the stalk and you're done. For 09 MT, same plus mount and plug in the clutch switch. No running of any additional wires on either.
Old 05-04-2009, 10:13 PM   #3
MGargano
Is there a DIY for mounting/wiring the clutch switch? I haven't gotten it yet so I'm not even sure what it looks like/where to put it.
Old 05-04-2009, 11:00 PM   #4
Take a look at this DIY on installing cruise on a Matrix. It shows the Clutch Switch installation:
http://matrixowners.com/index.php?ac...r&f=23&t=71247
Old 05-04-2009, 11:29 PM   #5
MGargano
Looks like the plug for this switch should already be hanging somewhere under the dash, if I'm reading this correctly. Seems pretty straight forward.
Old 05-04-2009, 11:36 PM   #6
Correct. Plug is hanging there. Remove bolt, screw in switch, plug in connector.
DIY Cruise Control on 07-08 Yaris (step by step) Vince87 DIY / Maintenance / Service 431 12-28-2020 01:37 AM
Cruise Control - Again! CB900F2 DIY / Maintenance / Service 47 06-17-2010 06:29 PM
Cruise control vs MPG YarisOwnersDad Fuel Economy Forum 15 05-29-2009 03:55 PM
