Old 05-05-2009, 09:14 PM   #1
With the 09's it seems that everything is pre-wired.
Here's what I believe is required:
Lock Assembly, Front Door W/Motor, RH: 69030-52470
Lock Assembly, Front Door W/Motor, LH: 69040-47060
If your's is a 5 door:
Lock Assembly, Rear Door W/Motor, RH: 69050-52190
Lock Assembly, Rear Door W/Motor, LH: 69060-52200
Actuator Assembly, Back Door Lock: 69150-52070
Mounting Bolts: 91511-B0614 (2 required)
Switch Assy, Door Control: 84930-52050 (Center console switch)
Old 05-06-2009, 08:47 AM   #2
IllusionX
Drives: 07 Yaris Sedan Aero
you also need the power lock control module...
for the LB, i believe it is located behind the cluster, could you find out the part number?
Old 05-06-2009, 10:59 AM   #3
That's just if you want keyless entry as well, as the ECM controls the power locks itself:
Door Control Receiver (with 2 wireless keys): 89741-52390
Toyota Online Parts Reference!!! ricepower DIY / Maintenance / Service 33 06-25-2024 01:30 AM
Toyota Parts Cheap.com regal Off-topic / Other Cars / Everything else Discussions 5 04-16-2009 11:10 AM
Auto Shop Local Bay Area Genuine Toyota Parts Low Low Price with Warrenty YarisSedan California 1 10-31-2008 08:32 PM
Toyota Parts finder site ricepower DIY / Maintenance / Service 2 10-20-2008 08:29 AM
Toyota Delays Buckethead General Yaris / Vitz Discussion 3 08-26-2006 03:16 AM
