My R1 eats my Vitz!!
Drives: '07 Vitz Lifty, Stick Shift Join Date: May 2007
CTScott, I checked every pin (just to be sure) on those two IC's (IC500,IC501) and the pins for the blank spot where the third IC should go (IC502). Nothing :( they were all the same after I hit the Cruise switch. I grounded my meter to the frame and checked the pins with the red lead of the meter while it was on DC Voltage "20V" setting. That's how I do it right (I don't think I'm that dumb, but just to make sure) I guess it's not gunna happen the easy way as usual :)
My Car Rules! |
#2 | |
Sounds like you tested it correctly. As PK mentioned prior, there was little chance that it would be there, but it was worth a shot. I have to order some parts today for another project, so I'll order what I need as well to test my method of lighting your LED. |
#3 | |
I received the parts this week for lighting your LED, without changing your switch. I will be using a PIC12HV615 microcontroller to sense the switch press (and differentiate between the on/off and one of the other ones being pressed) and to drive the LED. The entire circuit will only require the 8 pin microcontroller, a transistor, and a few resistors (totaling maybe $5 in parts). I will hopefully have some time this weekend to experiment. PM me your mailing address, and when I have it all figured out, I'll mail you the "module" (at no charge, since you've been the guinea pig for this). |
| DIY - 2009 Cruise Control for $10, without pulling the steering wheel and airbag | CTScott | DIY / Maintenance / Service | 307 | 04-04-2023 03:43 AM |
| DIY Cruise Control on 07-08 Yaris (step by step) | Vince87 | DIY / Maintenance / Service | 431 | 12-28-2020 01:37 AM |
| Cruise Control - Again! | CB900F2 | DIY / Maintenance / Service | 47 | 06-17-2010 06:29 PM |
| Cruise control vs MPG | YarisOwnersDad | Fuel Economy Forum | 15 | 05-29-2009 03:55 PM |
| Using Cruise control | Driver | General Yaris / Vitz Discussion | 14 | 11-09-2006 10:12 PM |
