Old 05-06-2009, 06:33 AM   #1
stran
Drives: '07 Yaris 3D HB Auto
Correct. That's what I did with mine. In any vehicle that I've had with cruise, I never find myself using the tap up/down or coast/resume, so I just went with two switches.
If you push once to turn the cruise switch on. Then turn off the car, and turn the car back on again. Is cruise still on?
stran is offline   Reply With Quote
Old 05-06-2009, 07:37 AM   #2
No. It resets with the ignition.
Old 05-06-2009, 10:33 AM   #3
mariann
Drives: yaris 2007
it a wired question but...
i understand the on/off buton is for turning the cruise controll on and off
so whats the set button does? why i need two buttons? any one can explain me how to work with cruise controll?
mariann is offline   Reply With Quote
Old 05-06-2009, 10:48 AM   #4
On/Off turns the cruise control mode on or off.
Set selects the desired speed (above 25mph).
So, you can turn it on at any time, then, once you want to be in cruise mode, you attain your desired speed, and press the set button. At that point you can take your foot off of the accelerator.
To resume manual speed control, you either press the on/off button or touch the brake pedal.
Old 05-06-2009, 11:02 AM   #5
nickhjort
My R1 eats my Vitz!!
nickhjort's Avatar
Drives: '07 Vitz Lifty, Stick Shift
Or hit the clutch once you install the clutch switch am I right?
My Car Rules!
nickhjort is offline   Reply With Quote
Old 05-06-2009, 11:30 AM   #6
Correct.
OEM foglight switch and leather wrap steering wheel 808yarisLB Cosmetic Modifications (Exterior/Interior) 8 03-11-2009 12:05 AM
SCION SPORT STEERING WHEEL, RED, XA AND XB, 03 TO 06 justoneyaris Items for Sale by private party 3 12-04-2008 06:30 PM
steering wheel setup aucorium Cosmetic Modifications (Exterior/Interior) 0 07-24-2007 01:05 AM
How do you take off steering wheel mrrock Cosmetic Modifications (Exterior/Interior) 3 12-05-2006 10:16 AM
