Old 05-06-2009, 09:10 PM   #1
sheraz2000
sheraz2000's Avatar
Drives: Vitz 2006
Send a message via MSN to sheraz2000
Wiki says that:
"The 1KR-FE is a 1.0 L (998 cc) version built in Japan and Poland. Bore is 71 mm and stroke is 84 mm, with a compression ratio of 10.5:1. Output is 68 hp (50 kW) at 6500 RPM with 68.6 ft·lbf (93.0 N·m) of torque at 3600 RPM. Carbon emission levels are 109 g/km."
---- its fun to be in a vitz!
sheraz2000 is offline   Reply With Quote
Old 05-06-2009, 11:30 PM   #2
PHXDEMON
PHXDEMON's Avatar
Drives: 2007 Red Liftback
Originally Posted by sheraz2000 View Post
Wiki says that:
Wow that is fucking weak so yeah a 1nz swap would boost you up 38 crank horsepower assuming that wiki is speces @ the crank not the wheels.
Old 05-07-2009, 04:46 AM   #3
jambo101
jambo101's Avatar
Drives: yaris 08 sedan
I think the small engine in this car is always going to be a problem so changing it to the 1.5l will at least get you into more options for aftermarket go fast add ons.
Or you could trade the car for something a bit bigger like this http://www.cardomain.com/ride/2578665
Tags
1kr-fe
