![]() ![]() ![]() Drives: Polar White Yaris HB Join Date: Dec 2008
Another mod which will make a dramatic difference are rims....
I am using Enkei RPF1. They only weight9.5lb eash which is WAY lighter than the stock 16lb steel rims. Many light aftermarket are around 12-13.5. With the lighter and wider rims you get better...... Acceleration Braking Cornering Suspension response Another super easy mod is upgrading your grounding system to a large 0 guage wire connecting the negative terminal to the body. This helped my throtle response and made shifting smoother(auto trans). |
#2 | |
![]() Drives: 3 Door Hatchback 5 speed "S" Join Date: Mar 2009
Thats cool how a little wiring can make a change...This probably won't be effective in a manual though, right? |
| pulled and rolled | BrazdonW | Cosmetic Modifications (Exterior/Interior) | 30 | 05-06-2009 11:23 PM |
