Old 05-08-2009, 12:17 AM   #1
07WYarisRS
HardlyDangerous
07WYarisRS's Avatar
Drives: 09 Yaris LE, H/B, auto
Originally Posted by DerFlosser View Post
Possibly placebo but a higher octane fuel should ignite better so a smoother start really is possible.
Higher octane fuel had a higher flash point... That means its harder for higer octane to ignite thats why its only to be used in high compression engines to eliminate knock...
So many people know so little about fuels and its affects its enough to make your head spin. Why people will continue to argue the effects of running different octanes is beyond me...
Run only the octane needed to prevent detonation, anything higher is waisting $$$ and costing you performance as a higher octane with higher flash point is harder to ignite and can waist fuel...
If your engine is knocking on 87 octane it either because you have a problem, your buyin shitty ass gas or you ran high octane fuels for a time and have a carbon build up problem.
i've been building and rebuilding race engines and regular engines for many years and have done many tests on the dyno and using CHT/EGT guages.
Facts are facts people. running a higher octane in a n engine that was designed to run a lower octane is not doing ANY good.. in fact it does more harm then good
The early bird gets the worm, but the second mouse gets the cheese.
07WYarisRS is offline   Reply With Quote
Old 05-08-2009, 12:48 AM   #2
06vitzRS
Drives: 06 Yaris HB
+1
But i'm just a mechanic so what do i know.
It would be soooooo nice to put this topic to rest....probably not going to happen, oh well.
4th year apprentice mechanic.
06vitzRS is offline   Reply With Quote
Fuel Efficiency and the Yaris BailOut Fuel Economy Forum 327 01-02-2026 11:44 PM
Fuel Economy swng Fuel Economy Forum 2089 01-23-2015 06:41 PM
Yaris Fuel Pump HTM Yaris General Yaris / Vitz Discussion 12 03-22-2012 03:34 AM
Last Fuel Bar andaconda Fuel Economy Forum 37 04-29-2009 02:35 PM
The Advantages of Nitrous on an Engine KCALB SIRAY Performance Modifications 7 01-02-2009 10:53 AM
