#1 | |
![]() ![]() Drives: 2009 Yaris with TRD parts Join Date: Nov 2008
First of all, small chambers (inherent to a small displacement engine) are more efficient than larger ones because flame propagation occurs over a smaller area. That's the main reason that motorcycle engines are able to run such lofty compression ratios. Secondly, the Yaris is one of the few engines that offers DIRECT INJECTION - which cools the intake charge and as discussed in the following link: http://www.greencarcongress.com/2009...portfolio.html 10.5:1 is not a high compression ratio for a modern, direct injected, small displacement engine. The 2.4 liter, direct injected GM engine discussed in the link above runs an 11.4:1 CR! Hence, the 10.5:1 compression ratio in the Yaris engine (where each cylinder represents a mere ~ 0.375 liters and where direct injection is involved) isn't comparable to an engine that utlizes port injection and larger cylinders (particularly the bore dimension). What amazes me about these bulletin boards is that people voice opinions without having any REAL understanding of the subject matter, most of which boils down to advanced engineering principals. There is absolutely, positively NO EMPIRICAL EVIDENCE supporting the notion that any modern engine that has a recommended fuel octane rating of 87 PON can, in any way, benefit from a gasoline of a higher octane rating. If anything, empirical evidence suggests the opposite, since the slightly lower burn rate of the higher octane fuel may adversely impact the intended timing of the complete combustion process, relative to the position of the piston and the valves. Last edited by 427chev; 05-08-2009 at 06:11 PM. |
Well said 427chev,i think most people fall into the marketing hype of naming the higher octanes with such colorful names (Super,deluxe,Premium,Gold etc)as to make 87 octane seem inferior,so they only fill up with that superior high octane and talk themselves into believing that they are somehow getting more power and better fuel economy without ever doing any meaningful measurements of whats really going on .
#3 | |
http://www.fuelsaving.info/fuels.htm |
| Fuel Efficiency and the Yaris | BailOut | Fuel Economy Forum | 327 | 01-02-2026 11:44 PM |
| Fuel Economy | swng | Fuel Economy Forum | 2089 | 01-23-2015 06:41 PM |
| Yaris Fuel Pump | HTM Yaris | General Yaris / Vitz Discussion | 12 | 03-22-2012 03:34 AM |
| Last Fuel Bar | andaconda | Fuel Economy Forum | 37 | 04-29-2009 02:35 PM |
| The Advantages of Nitrous on an Engine | KCALB SIRAY | Performance Modifications | 7 | 01-02-2009 10:53 AM |
