In between cities
Drives: 2006 yaris ce Join Date: Feb 2006
i got Vredestein hi-trac which is amazing in the wet and not bad in the dry. It does have low-rolling resistance it helps with the fuel mileage. Check out this web site on test for a set of popular tires in europe. I helped me choose mine! but also depends on what type of tire you want for the dry or wet.
http://www.autoexpress.co.uk/product...yre_guide.html |
Taking care of Bubbles
Drives: 2009 Yaris LB "Bubbles" Join Date: Apr 2009
I've already decided on the next tires "or shoes" for Bubbles. I did a search on Tire Rack with decending UTQG "treadwear" and with the best price. The results were the same as BAIL OUT indicated. Yokohama Avid TRZ.
Bubbles is very happy about getting his new shoes, but I told him that he needs to wear out his Goodyear LS's first!
2009 Absolutely Red LB. "Bubbles" |
#3 | ||
50 MPG or BUST!
![]() Hopefully I'll be picking up the Avid TRZ tires next weekend so I can give you a heads up on any immediate FE change from the LS's. (the temp and my commute shouldn't change that much over a week so any change will probably be due to tires, for good or for ill.) Quote:
| Yaris Fuel Pump | HTM Yaris | General Yaris / Vitz Discussion | 12 | 03-22-2012 03:34 AM |
| Newly installed 15" tires feel 'weird' | kristan | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 20 | 04-24-2010 06:58 PM |
| Last Fuel Bar | andaconda | Fuel Economy Forum | 37 | 04-29-2009 02:35 PM |
| The Advantages of Nitrous on an Engine | KCALB SIRAY | Performance Modifications | 7 | 01-02-2009 10:53 AM |
