there will be more threads sticking thru the top of the strut top because the df's will be shorter than stock springs
the spring/strut combo up front is compressed together with a nut and cap that are separate from the nut you remove in the engine bay the process is 100x easier w/ an impact wrench...i used one installing my coilovers and had no issues removing the top nut.......however i sprayed every nut w/ penetrating lube the day before the install so all the nuts would crack easily... hope the rest of your install goes smoother...!
| Compilation of Yaris How-tos/DIYs | YarisBueller | DIY / Maintenance / Service | 39 | 04-28-2018 08:47 AM |
| Non-Yaris Audio install help needed | Revsson | In Car Entertainment + Electronics (audio / video / alarm) | 18 | 08-17-2009 11:47 AM |
| spring install help asap! DELETE | tristan | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 0 | 02-18-2009 01:30 PM |
| Suspension install: Spring Compressors? | Thirty-Nine | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 15 | 09-18-2007 10:59 PM |
| TANABE DF210 Spring Install [pics] | Chris07LB | DIY / Maintenance / Service | 148 | 07-16-2007 09:26 PM |
