Old 05-09-2009, 10:36 AM   #1
mrbond
mrbond's Avatar
Alright, so just to sum it up for the stalk usage: I remove the airbag, install the stalk like in that Matrix link, then run a wire from the D connector to a ground point, and then the other wire straight to pin #40 in the ECM?
Do I mess with A21, or do I just do what I wrote in the above paragraph? (and this is all just if I don't bother with the clutch switch just yet)
- A Toyota Yaris
- A whut Yaris?
Old 05-09-2009, 11:32 AM   #2
Correct.
Remember that in order to even test it, you will need to bypass the clutch switch at the under hood fuse panel connector.
DIY - 2009 Cruise Control for $10, without pulling the steering wheel and airbag CTScott DIY / Maintenance / Service 307 04-04-2023 03:43 AM
DIY Cruise Control on 07-08 Yaris (step by step) Vince87 DIY / Maintenance / Service 431 12-28-2020 01:37 AM
Cruise Control - Again! CB900F2 DIY / Maintenance / Service 47 06-17-2010 06:29 PM
Cruise control vs MPG YarisOwnersDad Fuel Economy Forum 15 05-29-2009 03:55 PM
Using Cruise control Driver General Yaris / Vitz Discussion 14 11-09-2006 10:12 PM
