Old 05-10-2009, 02:27 PM   #1
talnlnky
Audio Junky
talnlnky's Avatar
Drives: 08 liftback
Originally Posted by skigil View Post
I noticed that since my sub is in where the spare tire used to be (and is facing up), most of the bass stays within the car. The bass can be nice and loud inside the car, but you can barely here it outside the car. It's either the positioning, or the fact that my enclosure needs to be redone in MDF (I did it out of some old 3/4" plywood I had laying around).
Does anyone have thoughts on this?
WOW.... i really can't believe you are complaining.... You've got bass to yourself... and minimal leakage out to the rest of the world... thats near perfect. You're not pissing people off... you're not giving car stereo too bad of a name.... and you want it more outside...
Roll down your windows, fold down your seat, or pop the trunk/hatch. Tho if you did that around me... i'd prolly cut you off and drive 5mph in front of you.
If you want to seriously increase your volume there are basically only two ways to do it that are cost effective. Buying a bigger amp is not cost effective unless you are talking about a 500+rms sub and only have 100w on it.
1: remove any obstacles that are physically inbetween you and the sub (rear seats, Trunk cover if in a spare tire well). Allow that sub to breath!
2: Make a custom box for it that is designed to put higher levels of pressure on the cone. Higher the levels of pressure on the cone the higher the output will be. Ported boxes are awesome... Not all subs play nicely with ported boxes however... And not all ported boxes are designed to be nice to subs... the one found in stores usually are poorly designed.
if you go from sealed to a properly ported design.... you will hear sound outside your car... you will have more rattles... and your sound could be anywhere from 2-10dB louder depending on how you tune it... So go throw on some dynamat/fatmat/raammat cause you will start to annoy the world otherwise.
Old 05-11-2009, 06:18 PM   #2
PHXDEMON
PHXDEMON's Avatar
Drives: 2007 Red Liftback
Just wanted to point out from experience that a ported box with a fosgate HE2 will go relly low and bump really hard, however it won't hit very "tight" If you listen to nothing but rap,dub-step, and bass tester CDs then it will be great but for just about any other type of music you will sacrifice a lot of accuracy with a ported enclosure.
Old 05-18-2009, 04:29 PM   #3
talnlnky
Audio Junky
talnlnky's Avatar
Drives: 08 liftback
not true.. the accuracy you speak of is dictated by basically 2 variables. 1) the Le (inductance of the coil) 2) the box size and port tuning. Most applications of ported boxes suck because the box isn't tuned low enough, and the transient response in the 40-60hz range is horrible. Add to that most car subs, especially the more expensive ones that claim higher power handling usually suck at the Le part as well.
Regardless, even a horrible sub can sound fairly accurate if port in a properly designed ported box... and vice versa.
The First Annual Kevin Duckworth Scholarship Car Show kingpincaraudio Northwest 5 06-24-2009 01:32 PM
Jerkratt - Photo Scavenger Hunt Jerkratt Photo-Video-Media Gallery 3 03-04-2009 09:03 AM
Custom Lftback - Photo-Scavenger Hunt custom Lftback Photo-Video-Media Gallery 2 03-01-2009 11:12 PM
Darb - Photo Scavenger Hunt Darb Photo-Video-Media Gallery 3 03-01-2009 09:02 PM
TRD, DC Sports, Nitto, Greddy Ti-c Inside car Video Clip Jerkratt Performance Modifications 7 12-24-2008 04:19 PM
