Old 05-13-2009, 07:48 AM   #1
Originally Posted by IsLNdbOi View Post
I tried sliding the HU through the front and the back and it wouldn't fit. It's not just the corners. As I mentioned above, the FH-P8000BT has a faceplate permanently attached to it that can't be removed. I took the entire thing out and it does have screws to remove the entire front of the unit. When you do that, you find that the parts circled in red are permanently attached / molded into / is one piece w/ the entire front of the head unit.
I've circled it in red here:
In doing some searching, I see mention of it being common to have to trim to fit the FH-P8000BT. I couldn't find actual dimensions for that ring. Usually the installation manual has the detailed dimensions, but not for that Pioneer.
CTScott is offline
Dash destroyed in electrical fire. purpleminx General Yaris / Vitz Discussion 79 06-12-2009 03:53 PM
Double Din 180mm Trim Bezel esyres In Car Entertainment + Electronics (audio / video / alarm) 19 03-19-2009 09:01 PM
[Recovered] Group Buy for Australia #1 (Badges) harveyjai Australia 9 12-13-2008 03:59 PM
