Old 05-13-2009, 03:59 PM   #163
pariahdecss
Yarisomniac
pariahdecss's Avatar
Drives: 2009 5spd LB
Yes my HU is a Kenwood DNX7120 and I had to trim the new trim piece (not the headunit) about 10mm on the back lip to make it fit - for those that are really picky the color of the new piece for my '09 LB is not a 100% match against the center AC/Air center gauge cluster trim but I am fine with that. The new trim piece is lighter than the slightly darker/smokier USDM center gauge panel.
. . . but it still looks hella better than the Metra® gap filler crap kit
pariahdecss is offline
Old 05-13-2009, 04:31 PM   #164
I just popped mine off to take some measurements. My Eclipse AVN2210p (which is actually the radio that Toyota made this piece because of) has a wider trim ring, which is about 1" in from the face. You can see it in the picture below. The wider ring is 179mm x 97mm. The narrower section is 170mm x 94mm.
The new trim piece's opening is 174mm x 100mm (6 7/8" x 3 15/16"). This is 6mm narrower than Double DIN spec, which probably explains why some HU's fit without a problem and others don't.
Also, the lip of the new trim piece extends 10mm deeper than the original did (see the pic below).
CTScott is offline
Old 05-13-2009, 05:07 PM   #165
IsLNdbOi
IsLNdbOi's Avatar
Thanks Scott. Keep me on the list. I'll try taking pics. later. I just find it a PITA to remove the trim pieces and panels to take the HU out.
IsLNdbOi is offline
Old 05-13-2009, 05:19 PM   #166
Grab the vertical trim pieces low, on the outside (by the storage pockets) and pull outward. They come off much easier from bottom to top.
CTScott is offline
Old 05-13-2009, 06:03 PM   #167
enviri
enviri's Avatar
Drives: 2010 Yaris
scott add me to the list too, its time for me to start getting a system.
enviri is offline
Old 05-13-2009, 06:13 PM   #168
It has arrived in Canada!
Will try to install tomorrow night. HU will be JVC.
WeeYari is offline
Old 05-14-2009, 04:25 AM   #169
IsLNdbOi
IsLNdbOi's Avatar
I tried trimming all around the back of the trim piece. Trimmed all the way to the line on the surface where you can see where the plastic was "joined" together.
Still no go. This is the best pic. I could take of it.
It's like this on both sides:
I do plan on getting the new version of the P8000BT later this year. They've released new versions of most of their 2008 models already. Hopefully, they don't add the stupid faceplate on the new model.
I do still want another of these DD trim pieces Scott so keep me on the list.
IsLNdbOi is offline
Old 05-14-2009, 10:42 AM   #170
If I understand correctly, you're trimming the lip of the trim piece to make it less deep? If that is the case, how close is it depth-wise from the trim piece being able to snap on? Also, if you were able to move the HU in deeper (by re-drilling the bracket mounting holes), would that help?
CTScott is offline
Old 05-14-2009, 11:23 AM   #171
Danish Yaris
Drives: Toyota Yaris 1,8 TS 5dr. 2007
Hi
That´s because the radiopanel is made for the non faceliftet model which is a lighter silver in color.
Regards Steven.
Danish Yaris is offline
Old 05-14-2009, 04:53 PM   #172
IsLNdbOi
IsLNdbOi's Avatar
Yes, I thought that's what everyone was telling me to try in the previous posts in this thread. It doesn't look very nice though. You can see in the picture that the trimmed lip can be seen.
Not sure how close it is to being able to snap on. Didn't take that measurement. I don't think moving the HU in deeper would help. The problem is the attached ring / faceplate on the front of the HU.
IsLNdbOi is offline
Old 05-14-2009, 06:48 PM   #173
SHIT!!
It's not going to work without some jigging. Going to have to shave about a quarter of an inch off of the sides of the HU opening in the trim panel.
WeeYari is offline
Old 05-14-2009, 07:47 PM   #174
SHIT!!
What HU do you have?
CTScott is offline
Old 05-14-2009, 07:52 PM   #175
JVC
WeeYari is offline
Old 05-14-2009, 08:06 PM   #176
JVC
Looking at an unmounted picture of your KW-XG700, it has a similar lip to IsLNdbOi's Pioneer. Does the narrower part beyond that lip fit through the opening, or is that the area that needs to be trimmed for?
CTScott is offline
Old 05-15-2009, 12:31 AM   #177
IsLNdbOi
IsLNdbOi's Avatar
The manual for the P8000BT shows this for the dimensions:
Dimensions (W × H × D):
D
Chassis ..................... 178 mm × 100 mm × 160 mm
(7 in.× 3-7/8 in.× 6-1/4 in.)
Nose ........................... 170 mm × 94 mm × 8 mm
(6-3/4 in.× 3-3/4 in.× 3/8 in.)
I couldn't get the P8000BT in even through the front of the new trim piece.
IsLNdbOi is offline
Old 05-15-2009, 06:17 PM   #178
...and it's in...
Ground off the positioning pins on the HU mounting brackets. Was then able to position HU further back.
WeeYari is offline
Old 05-17-2009, 07:02 AM   #179
IsLNdbOi
IsLNdbOi's Avatar
So after grinding the pins off and mounting the HU further back, does any part of the HU even touch the new 180mm DD trim piece?
IsLNdbOi is offline
Old 05-17-2009, 07:41 AM   #180
The face frame of the HU measured 178mm, with an extended nose at 170mm.
By repositioning the HU, the trim now 'rests' on the 178mm portion of the face frame. There is no contract being made on the inside of the trim piece opening.
WeeYari is offline
Dash destroyed in electrical fire. purpleminx General Yaris / Vitz Discussion 79 06-12-2009 03:53 PM
Double Din 180mm Trim Bezel esyres In Car Entertainment + Electronics (audio / video / alarm) 19 03-19-2009 09:01 PM
[Recovered] Group Buy for Australia #1 (Badges) harveyjai Australia 9 12-13-2008 03:59 PM
