Old 05-15-2009, 09:44 AM   #1
cdydjded
Drives: Yaris LB Turbo
Our cars use what called a "returnless fuel system". The regulator is in the fuel tank, not on the fuel rail. It is not adjustable. You would have to convert to a "return" fuel system to be able to adjust your fuel pressure. Unless you are running a S/C or turbo you fuel pressure does not have to be adjusted, even with all the bolts on's available for our cars.
cdydjded is offline   Reply With Quote
Old 05-15-2009, 10:01 AM   #2
Russelt3hPirate
l33t3st Asshole
Russelt3hPirate's Avatar
Drives: MY07 Yaris Liftback
hmm, converting to a return fuel system would be entertaining.
might as well gut the car, ligthen the wiring, and re do the ENTIRE fuel system while you're at it....
research time.
Russelt3hPirate is offline   Reply With Quote
Old 05-15-2009, 10:53 AM   #3
LtNoogie
LtNoogie's Avatar
Drives: '08 Bayou Blue LB AT
I have a S/C'd Yaris running tC injectors. The injectors are too big and the car throws a rich mixture CEL every time I start the car. I am thinking of getting a boost-compensated adjustable fuel regulator that I can turn down the psi until my data logger shows that the ECU is no longer struggling to trim back the fuel.
I expect that at my 6psi full boost pressure that my fuel pressure will go up 6psi and keep me at a nice AFR.
