Old 05-15-2009, 02:32 PM   #1
Tamago
Tamago's Avatar
Drives: UZJ100
Originally Posted by ROCKLAND TOYOTA View Post
i have tein springs and 205-55-15 dunlops. 15x? and what offset are i looking for......
15X7, +35 will be fine. minimal rubbing will occur that can be solved with a heatgun to the bumps in your fender liners.
Old 05-15-2009, 02:38 PM   #2
ROCKLAND TOYOTA
TRIM HUNTER
ROCKLAND TOYOTA's Avatar
i have scion xa/xb 10 spoke wheels 15x?. whats those specs and will they work in my situation.
Old 05-15-2009, 02:41 PM   #3
Tamago
Tamago's Avatar
Drives: UZJ100
15x6 most likely
they'll work fine..
buy 20mm spacers for the rear
Old 05-15-2009, 02:44 PM   #4
ROCKLAND TOYOTA
TRIM HUNTER
15x6 most likely
they'll work fine..
will your 30's be too much?
Old 05-15-2009, 02:45 PM   #5
Tamago
Tamago's Avatar
Drives: UZJ100
my 30's?
Old 05-15-2009, 02:53 PM   #6
ROCKLAND TOYOTA
TRIM HUNTER
my 30's?
weren't you polling to see if anyone was interested in 10 or 30mm spacers from you? also are spaces good with autocrossing.....
Old 05-15-2009, 02:54 PM   #7
Tamago
Tamago's Avatar
Drives: UZJ100
that's 10 and 13
http://www.yarisworld.com/forums/sho...ht=hub+spacers
they'll be released for sale by the first of june.
with that wheel/tire package, you could easily run 13MM
they are great with autocrossing, are a great "in addition to" mod when doing a swaybar.
Old 05-15-2009, 02:41 PM   #8
Nexus1155
Bathroom + Laptop = <3
Drives: Audi
Tamago I have K16 turbos on a 2.7L Engine, These turbos were meant to go on a 3.6L 997 Porsche
When do you think I will getting full boost by and how much power do you think i will make at 21psi
here is the map for good reference or a k16 map that is
http://www.sjmautotechnik.com/parts_.../turbo/k16.GIF
Old 05-15-2009, 02:42 PM   #9
Tamago
Tamago's Avatar
Drives: UZJ100
wow that's hard to read.
what is the compression ratio of each engine, how will the charge air be cooled, and what are your injector sizes?
The open political discussion thread. Read the first post! eTiMaGo Off-topic / Other Cars / Everything else Discussions 342 09-15-2009 12:34 AM
Post Whores-aka Yaris chat thread Black Yaris Off-topic / Other Cars / Everything else Discussions 21 07-12-2007 05:37 PM
