Old 04-06-2006, 01:51 PM   #1
swng
swng's Avatar
Drives: 06 3-dr auto RS
If I were in your same position, I will just follow the owner's manual and let Toyota deal with any problems that may arise. It should be their problem.
swng is offline   Reply With Quote
Old 04-06-2006, 07:42 PM   #2
why?
Only Happy When it Rains
why?'s Avatar
Drives: Yaris LB
It really depends on whether or not you are going to keep the car at the end of the lease.
If you are, take care of it. If not, then don't worry too much and do only what is prescribed.
Old 04-06-2006, 09:17 PM   #3
echo_hrs
Around the universe...
Drives: Uber-Evolved Pokemon
Heck, neglect the sucker, and when it blows up, swap the 1.8 into it...
echo_hrs is offline   Reply With Quote
Old 04-07-2006, 09:01 AM   #4
why?
why?'s Avatar
Drives: Yaris LB
Heck, if you are going to swap an engine in why not go all the way and drop a MkIV Twin Turbo Supra engine in the back and make it rwd.
Old 04-07-2006, 12:26 PM   #5
jcove
jcove's Avatar
Drives: 2011 Rogue
jcove is offline   Reply With Quote
Old 04-09-2006, 09:57 PM   #6
Ron
Drives: BBM Yaris HB
i went in for my first oil change at roughly 6500km. my next service is not due until 14,500km, so 8000km interval or 6 months. i will most likely do my own oil/filter changes at the 10k, and 15k intervals just to keep things easily trackable. at the 15k interval, i will be going to a synthetic oil
had i known that my first service was not free, i would have done the oil change myself and save myself the $20 difference.
Ron is offline   Reply With Quote
Old 04-09-2006, 10:25 PM   #7
stuffy
stuffy's Avatar
Drives: 06 yaris 5-dr le man
hey ron, what are the advantages of synthetic oil, and why are you waiting until 15k?
stuffy is offline   Reply With Quote
Old 04-10-2006, 02:15 AM   #8
Ron
a full synthetic oil is better at lubricating the engine parts, and has detergents and other additives to help the motor run cleaner reducing carbon build up. it is also more durable than conventional dino oil, allowing oil change intervals to increase.
it is recommended to switch to a synthetic after 12-15k km's so that the rings are properly seated in the motor. the initial break-in for the motor is 1000-1500km's according to the manual, but the actual break-in continues on until 12-15k km's. if you switch to a synthetic too soon, its superior lubricating properties may cause the rings to not fully seat as well as with a dino oil.
for older high mileage (200k and up) cars that have been using dino oil all along, switching to a synthetic may actually cause leaking to occur as the detergents in the synthetic oil 'cleans' out any build ups and deposits internally which may be preventing oil leaks. so older cars that have been on dino oil all along, are recommended generally to stick with dino oil.
Old 04-10-2006, 06:42 AM   #9
jcove
jcove's Avatar
Drives: 2011 Rogue
I don't agree 100% on the old car scenario. I agree it CAN cause leaking, but it also cleans up the engine, it runs smoother and you get better milage, due to less friction from the synthetic. I think the pro's outweigh the con's on an older engine. It'll keep it running longer. The leak that you may see in theory, shouldn't be much more than a slight leak, so it's not going to be a huge deal. Just my 2 cents though, not trying to argue.
Old 04-10-2006, 12:30 PM   #10
Ron
true, that is just a scenario. it doesnt happen all the time, but my last 2 cars before the yaris, were at 290k and 255k km's. both had been on dino oil for their life, and its not that dino oil doesnt work well. its just that synthetic works better. IF a leak was sprung from switching to synthetic, there really isnt any way to fix it without replacing seals, gaskets, etc etc. personally for me, the cons outweigh the pros. with a high mileage car, i just make sure the dino oil gets changed every 3-4k km's.
Old 04-10-2006, 09:22 AM   #11
why?
why?'s Avatar
Drives: Yaris LB
Also note some luxury car manufacturers like BMW and Mercedes deliver their vehicles to the dealerships with synthetic oil already in them.
Old 04-10-2006, 10:20 AM   #12
foober
Drives: two yaris liftbacks
i've used synthetic mobile 1 oil in my two trucks for the last 10 years or longer. And my mechanic has mentioned that my engine is like brand new. That there is no sludge in the engine at all. They both still run very well so I guess I'm doing the right thing.
foober is offline   Reply With Quote
Old 04-10-2006, 09:24 PM   #13
stuffy
stuffy's Avatar
thanks for the feedback guys
Old 04-11-2006, 04:19 PM   #14
Ziv
It's all about VVTI
Ziv's Avatar
Drives: Yaris 5Dr LE White
Hey guys, for those who are in Ontario, I just received a new coupon that if I do my oil change before end of May or somethin' I receive a LED flashlight. If you did not receive the coupon, bug them now.
Ziv on Vitz '06.
Ziv is offline   Reply With Quote
Old 04-14-2006, 05:45 PM   #15
yariman
Speed Wrenchin'
yariman's Avatar
Drives: 2006 Yaris 3 door, Bayou Blue
Not going to get into the whole shpeel again, but synthetic oil sometimes leaks cause it "flows" better. It will seep out of spots that conventional oil won't. Because it flows better, it is better oil. Switch to it when you want, however in past posts Toyota recomends waiting til 16000KM. As far as oil change intervals, the more often the better. 5000K intervals will help your engine last longer, but if you are not going to keep the vehicle forever, 8000K will certainly not harm it.
Quench my thirst with gasoline
yariman is offline   Reply With Quote
Old 06-03-2006, 03:56 PM   #16
swng
swng's Avatar
Yes, I have received mine too. I am in BC. I had my oil changed on June 1st. I stayed with conventional oil. The flashlight was probably one of the last few that the dealership had. I am glad I have acted fast enough. Thanks!
Old 06-05-2006, 02:46 PM   #17
Ziv
It's all about VVTI
Ziv's Avatar
Lucky you got it! I was lil late when I arrive at RH Yota, they said they ran out already and doubt there are any left in ontario.
Ziv on Vitz '06.
Old 06-05-2006, 07:36 PM   #18
swng
swng's Avatar
Sorry to learn about that . Good luck next time!
Anyway, it may cost you only a few dollars to buy one from the market.
Yaris stereo change PDFs YarisBueller DIY / Maintenance / Service 13 10-15-2022 04:52 AM
Fuel Economy swng Fuel Economy Forum 2089 01-23-2015 06:41 PM
When to switch to synthetic oil? jay DIY / Maintenance / Service 65 02-15-2007 08:44 PM
Oil change question Ryu DIY / Maintenance / Service 22 03-07-2006 11:21 PM
