![]() ![]() ![]() ![]() ![]() Drives: yaris 08 sedan Join Date: Oct 2008
Non interference engine
My Echo has surpassed 200k and as the Yaris has a similar/same engine i was wondering if these engines will eat the valves if the timing chain breaks..
Half a Bubble Off Plumb
I'd bet on it going "CRUNCH!" It has a 10.5:1 mechanical compression ratio, which doesn't leave a lot of clearance space, and the valve notches on the pistons don't look that deep to me.
Is there a service recommendation for replacing the chain? |
Owners manual says to replace at 160,000kms and i now have over 200,000kms
If i were going to keep the car i'd be thinking replacement but i'm hoping to trade it in for a newer Toyota in the next month or so. |
you must be smoking GOOD stuffs... Maintenace manual does not state timing CHAIN replacement.
Learn to Relax
Drives: 2007, Meteorite, LB Join Date: Dec 2008
Trade, you got your money's worth.
![]() ![]() ![]() Drives: 2007 Yaris Hatchback Join Date: Jul 2007
that's a large risk you're willing to take, i'd trade it in sooner rather than later if that's the case. as for the damage, I doubt it
HardlyDangerous
Drives: 09 Yaris LE, H/B, auto Join Date: Jul 2006
timing chain does not need to be replaced at 160K
the chain should last the life of the engine providing you are using a quality synthetic BELTS however do need to be changed the Yaris does not have a timing belt
The early bird gets the worm, but the second mouse gets the cheese. |
I like learning new stuff. Went back and reread the owners manual and timing chain has no replacement interval, dont know where i got that 160kreplacement figure but i suspect it might have been something the salesman said when i bought the car.
![]() ![]() ![]() Drives: Yaris Join Date: Apr 2009
I believe it to be an interference motor so, if the chain or tensioner(s) failed, the motor would be toast but as stated, there is no service recommended for the timing chain or the guides. A quality synthetic helps greatly and that's why I stick with a little heavier oil in the car as well.
as already stated:
1nzfe = interference chain does not need replacing. you'll spend more money on parts and labor installing a new chain than you would for a low mileage longblock lol
#13 | |
Drives: 2008 Yaris Join Date: Oct 2008
Gene |
#14 | |
fortunately a complete engine can be had for under $400 that's less than most members blow on exhaust systems lol.
#15 |
#16 | |
www.car-part.com
| DIY: Intake Installation | redyaris | DIY / Maintenance / Service | 53 | 08-23-2014 05:34 AM |
| The last gas question | Tonavi | DIY / Maintenance / Service | 56 | 04-27-2009 08:40 PM |
| engine swap update | Adriaan | Canada | 5 | 03-03-2009 06:21 PM |
| The Advantages of Nitrous on an Engine | KCALB SIRAY | Performance Modifications | 7 | 01-02-2009 10:53 AM |
