![]() Drives: Yaris Sedan YRS Join Date: May 2009
Something loose in the engine.
HI everybody,
I have just joined this wonderful forum, happy to be between you! I have bought a Sedan Yaris 3 months ago ( brand new ). When I pass over some speed bump or something like that, I feel something jumps up in the engine compartment, as if something is loose ... Has anybody have a similar experience?
ONLY YARIS ! |
jack TOOLS in the trunk?
![]() ![]() ![]() Drives: 2008 Yaris 5 speed HB Join Date: Oct 2008
Check that your air cleaner cover is properly latched down. I have seen it a couple of times where a quick oil change place or an inspection will do a `courtesy check' of your fluids and filters and either forget or not figure out how to snap the cover clips back into proper position.
Thank you for your answer but the sound clearly comes from engine compartment.
Beside that, I hear this sound when the front wheels are passing on a speed bump or something.
ONLY YARIS ! |
#5 | |
Thanks for your answer... But what I hear seems to be the sound of a HEAVY thing jumping up and down... Doesnt seem to be something like air cleaner cover or similar things... But I am going to check it anyway...
ONLY YARIS ! |
Any Other Ideas?
ONLY YARIS ! |
![]() ![]() ![]() Drives: Big Yellow Join Date: May 2009
Wait till everything cools down and check to see if the exhaust is loose anywhere?
Taking care of Bubbles
Drives: 2009 Yaris LB "Bubbles" Join Date: Apr 2009
It's under warranty so take it to the dealer!
2009 Absolutely Red LB. "Bubbles" |
#9 | |
I will certainly check that. Thanks
ONLY YARIS ! |
I will absolutely do it at the end, but firstly I want some clue!
ONLY YARIS ! |
Any Other clues? similar experiences?
ONLY YARIS ! |
Mine was doing that. Found out the spare tire wasnt completely tightend down. Now the spare tools jump around a bit and clang around now too.
#14 | |
Thank you anyway ...
ONLY YARIS ! |
![]() ![]() ![]() Drives: bone f*ing stock Join Date: Dec 2008
check the motor mounts......? its the only thing i can think of, but if the car is new it shouldnt be an issue, how fast are you going over the speed bumps?
![]() ![]() ![]() ![]() ![]() Drives: . Join Date: Apr 2007
the hamster is off the wheel
AHHHHHHH!!!!!!!!!!!!!!!!!!!!!
#18 | |
Not that fast... say 25km/h
ONLY YARIS ! |
| DIY: Intake Installation | redyaris | DIY / Maintenance / Service | 53 | 08-23-2014 05:34 AM |
| The last gas question | Tonavi | DIY / Maintenance / Service | 56 | 04-27-2009 08:40 PM |
| engine swap update | Adriaan | Canada | 5 | 03-03-2009 06:21 PM |
| The Advantages of Nitrous on an Engine | KCALB SIRAY | Performance Modifications | 7 | 01-02-2009 10:53 AM |
