Old 05-19-2009, 01:34 PM   #11
Originally Posted by PatrickJohnson View Post
I'd love to see a schematic. I would be willing even to have some PCBs etched for people as drop-ins. Does this just drive the On/OFF LED? What about the SET light?
EDIT: I see you mentioned it can sense the difference between the switches, so I assume this drives both LED's. Again though, if you post the schematic I can etch actual circuit boards (instead of perfboard) for you or anyone else if there is interest.
It just drives the power LED. Because the switches are all paralleled together, the ADC is required to differentiate the on/off switch from the other three.
The problem with driving a SET LED, based on just the switch, is that there are too many conditions where you could press the switch, but not really be "set". Tonight I should have a chance to drop the schematic into ORCAD. If there was enough interest in the modules I figured I would do a run of boards.
DIY - 2009 Cruise Control for $10, without pulling the steering wheel and airbag CTScott DIY / Maintenance / Service 307 04-04-2023 03:43 AM
DIY Cruise Control on 07-08 Yaris (step by step) Vince87 DIY / Maintenance / Service 431 12-28-2020 01:37 AM
Cruise Control - Again! CB900F2 DIY / Maintenance / Service 47 06-17-2010 06:29 PM
Cruise control vs MPG YarisOwnersDad Fuel Economy Forum 15 05-29-2009 03:55 PM
Using Cruise control Driver General Yaris / Vitz Discussion 14 11-09-2006 10:12 PM
