Old 05-19-2009, 02:06 PM   #11
PatrickJohnson
Drives: 2008 Yaris LB
It just drives the power LED. Because the switches are all paralleled together, the ADC is required to differentiate the on/off switch from the other three.
The problem with driving a SET LED, based on just the switch, is that there are too many conditions where you could press the switch, but not really be "set". Tonight I should have a chance to drop the schematic into ORCAD. If there was enough interest in the modules I figured I would do a run of boards.
I see. pretty cool either way. I was thinking of just doing a cmos flip flop switch to run the LED. I figured I could use the connection made by the on/off to touch a flip flop circuit or a relay and reset it's state, turning on the LED. of course, that might be using a sledgehammer to drive a thumb tack :)
PatrickJohnson is offline   Reply With Quote
DIY Cruise Control on 07-08 Yaris (step by step) Vince87 DIY / Maintenance / Service 431 12-28-2020 01:37 AM
Cruise Control - Again! CB900F2 DIY / Maintenance / Service 47 06-17-2010 06:29 PM
Cruise control vs MPG YarisOwnersDad Fuel Economy Forum 15 05-29-2009 03:55 PM
