![]() ![]() ![]() Drives: '08 5-door Join Date: Apr 2009
For controlling an indicator light- has anyone considered a DPST switch for on-off? Wouldn't work for the stock cruise switch, of course, but it should be OK for the improvised setups. Too simple?
With a DPDT switch you'd still need a circuit to toggle the LED on and off. The circuit becomes simpler (a flip flop using two transistors or one IC), but is still required, as the switch is a momentary input, rather than a toggled one.
#3 | |
If someone can come up with a tidy module to make this work, it could be a minor cottage industry. It should work with the OEM switch installations, as well as the improvised ones. |
| DIY - 2009 Cruise Control for $10, without pulling the steering wheel and airbag | CTScott | DIY / Maintenance / Service | 307 | 04-04-2023 03:43 AM |
| DIY Cruise Control on 07-08 Yaris (step by step) | Vince87 | DIY / Maintenance / Service | 431 | 12-28-2020 01:37 AM |
| Cruise Control - Again! | CB900F2 | DIY / Maintenance / Service | 47 | 06-17-2010 06:29 PM |
| Cruise control vs MPG | YarisOwnersDad | Fuel Economy Forum | 15 | 05-29-2009 03:55 PM |
| Using Cruise control | Driver | General Yaris / Vitz Discussion | 14 | 11-09-2006 10:12 PM |
