Old 05-19-2009, 03:56 PM   #1
Originally Posted by Sir A.Y. Atoyot View Post
For controlling an indicator light- has anyone considered a DPST switch for on-off? Wouldn't work for the stock cruise switch, of course, but it should be OK for the improvised setups. Too simple?
With a DPDT switch you'd still need a circuit to toggle the LED on and off. The circuit becomes simpler (a flip flop using two transistors or one IC), but is still required, as the switch is a momentary input, rather than a toggled one.
Old 05-19-2009, 06:14 PM   #2
Sir A.Y. Atoyot
Sir A.Y. Atoyot's Avatar
Drives: '08 5-door
I get it now.
If someone can come up with a tidy module to make this work, it could be a minor cottage industry. It should work with the OEM switch installations, as well as the improvised ones.
Sir A.Y. Atoyot is offline   Reply With Quote
DIY Cruise Control on 07-08 Yaris (step by step) Vince87 DIY / Maintenance / Service 431 12-28-2020 01:37 AM
Cruise Control - Again! CB900F2 DIY / Maintenance / Service 47 06-17-2010 06:29 PM
Cruise control vs MPG YarisOwnersDad Fuel Economy Forum 15 05-29-2009 03:55 PM
