Slowy getting there
Ok thank you. Loren I was wondering what type of K sport coil overs you are using I see that they have 2 different types on their website?
#2 | |
What?
For street/autox use, especially just starting out, the Kontrol Pro kit should more than meet your needs. In fact, if you don't set them up properly (there are hundreds of ways to set them up wrong, it's easy to do), you may even be better off with STOCK suspension. Seriously, just starting out at autocross, I would recommend this:
Follow that list step by step and in the end you'll not only have a Yaris that handles pretty darned well, but you'll have gained an awful lot of knowledge about how the car handles completely stock, what adding rear roll stiffness does for you, what a difference tires make, and what a difference good alignment makes. If you just rush out and put a bunch of braces on the car, or a coilover kit, or whatever... you won't learn a thing. You'll just be out there treading water with a very adjustable suspension that you don't have a clue how to adjust. Fundamental autocross advice: Tune the driver first. When tuning (driver or car), change only one thing at a time so that you'll know exactly what THAT change did or didn't do for you. |
| Body kits from Thailand | cali yaris | Micro Image | 175 | 04-23-2010 12:42 PM |
| GTSPEC under bracing installed/pics | blacksandiegovitz | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 29 | 05-01-2009 10:45 AM |
| GTSPEC Bracing.... | Fluid Motorsports | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 17 | 11-11-2008 07:48 PM |
| under bracing/ bars | pinoypizzaboy | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 4 | 11-10-2008 09:09 PM |
