Old 05-20-2009, 02:55 PM   #1
Tamago
Tamago's Avatar
Drives: UZJ100
Just not looking to spend over $700 on a wheel/tire combo.
The 15x7 Konig's are great for what I want.
are you at least gonna get the +20's?
Old 05-20-2009, 02:57 PM   #2
33OH
Drives: '08 Yaris
I'm not up on offsets really, was just going by the recommended guide.
If I got +20, what would I need to do to compensate for it?
Old 05-20-2009, 02:59 PM   #3
Tamago
Tamago's Avatar
Drives: UZJ100
you'd want camber bolts, and a .060" washer installed under each rear bolt of your rear hub.
there's also this:
http://www.good-win-racing.com/Mazda.../21-1001A.html
Old 05-20-2009, 03:02 PM   #4
33OH
Drives: '08 Yaris
there's also this:
Nice wheel but it's the same specs as the Konig really. (except 20 vs 25 offset), and the Konig is still cheaper and I like the looks better.
Where can I get the camber bolts (and/or washer) for the Yaris?
Old 05-20-2009, 03:06 PM   #5
Tamago
Tamago's Avatar
Drives: UZJ100
Garm sells the camber bolts.. as well as summit racing, jegs, and your local auto parts store.
i sell the washers. but it's not really worth it to ship you a set.
it's a stainless washer, 1/2" inside diameter, and "thin".. most are .058-.064" thick. if you bought a set from me i'd grind them to clear the yaris hub and match pairs to not cause any undue toe in-out issues.
$8 shipped for enough washers to yield -3 degrees rear camber (which i do not suggest)
Tire rotation: Does TPMS recognize tire position? jcdrotos Wheels, Tires and Suspension Forum sponsored by The Tire Rack 17 03-17-2011 02:00 PM
Why does Tirerack reccomend 185/50R15s for seeminlgy ALL of their 15" rims? St_G Wheels, Tires and Suspension Forum sponsored by The Tire Rack 15 03-16-2011 06:29 AM
Higher Tire Pressure captainm27 General Yaris / Vitz Discussion 46 01-27-2009 10:17 AM
Tire diameter list grampi Wheels, Tires and Suspension Forum sponsored by The Tire Rack 7 06-04-2007 04:03 AM
The Tire inflation debate... Tankota General Yaris / Vitz Discussion 20 06-01-2006 07:09 PM
