Slowy getting there
Bracing
I'm looking in to getting bracing for my Yaris. I'm going to start auto-xing it. What would be the best bracing that I can get? I don't have alot of money to spend at the moment. BELIEVE IT OR NOT I WOULD LIKE TAMAGO TO CHIME IN. I like input and all opions taken. Right now I have DF210 springs and the TRD rear sway bar. Please say type of bracing and brand please
Check the rules for the class you want to run, as some of the bars you might add might bump you into a higher class.
Ultra Racing makes quite few braces for us. You'll definitely get both camps to chime in from "it doesn't to anything" to "it definitely stiffens your chassis".
Slowy getting there
I know. I was thinking about going with Ultra Racing and I know others will say GT Spec and some might say Tanabe. I won't be racing for points this season so I'm not really that concerned with class yet.
![]() ![]() ![]() Drives: Polar White Yaris HB Join Date: Dec 2008
If you are looking to strengthen your chassis on a budget, how about stiffening the chassis by welding some small diameter high strength cromoly tubing in strategic places?
Slowy getting there
If I had a welder that I could I would stitch weld most of the car. This my sound kiddish and dumb but I knid of want the "shine new piece". Thank you for the post though.
Just out of curiosity, how much of a difference does stitch welding make. What would actually be welded?
Slowy getting there
You stitch weld the seam between 2 pieces of metal where the factory only spot welded or they glued the pieces together you would be surprised how much it helps. I believe that it would put me in a class that the yaris would never really be a competitor in
Slowy getting there
Anyone else?
What?
If you're just getting started autocrossing, just drive the car as is. If you have money to spend, buy a good set of tires. Tires will make more difference than all of the braces you could ever put on the car.
Slowy getting there
Ok thank you. Loren I was wondering what type of K sport coil overs you are using I see that they have 2 different types on their website?
#12 | |
Apexing Egg!!
HighTach Motorsports 2007 Toyota Yaris-ARGH!! Mods: Tokico HTS, 6.6 kg F, 6.1 kg R custom springs, 23 mm RSB, 2-way TRD LSD, 15x7 +25 Team Dynamic wheels, 195/55/15 Dunlop Star Specs, Cobra Suzuka S |
#13 | |
What?
For street/autox use, especially just starting out, the Kontrol Pro kit should more than meet your needs. In fact, if you don't set them up properly (there are hundreds of ways to set them up wrong, it's easy to do), you may even be better off with STOCK suspension. Seriously, just starting out at autocross, I would recommend this:
Follow that list step by step and in the end you'll not only have a Yaris that handles pretty darned well, but you'll have gained an awful lot of knowledge about how the car handles completely stock, what adding rear roll stiffness does for you, what a difference tires make, and what a difference good alignment makes. If you just rush out and put a bunch of braces on the car, or a coilover kit, or whatever... you won't learn a thing. You'll just be out there treading water with a very adjustable suspension that you don't have a clue how to adjust. Fundamental autocross advice: Tune the driver first. When tuning (driver or car), change only one thing at a time so that you'll know exactly what THAT change did or didn't do for you. |
What?
BTW, I've been autocrossing for 13 years, been autocrossing and tracking my Yaris for a little over a year, I have NO braces on the car, and no intent to add any.
rarer than JDM -1 of 1!
Loren,
I completely agree with you. Many novices come to events with fully modded cars, running in some of the highest pax multiplier classes. Then i could take a stock yaris (last summer), and demolish EVO's, M3's, lots of cars over $40k. O.P., If you can drive a few events stock, do that. After that, you can move on to suspension, tires, and chassis stiffeners. Unknowingly at the time, I actually ended up modding the yaris almost verbatim step by step according to Loren's advice. I have been autocrossing subarus for 3 years now, going on four years, with a few events of supperlapping under my belt as well. My biggest improvements have been made I'd say this last season, where everything makes a lot of sense in-car now. And don't let anyone fool you, the yaris can surprise many unsuspecting "fanboy" drivers, and good drivers as well. |
My advice to you:
1. Get as much seat time as humanly possible for improvement. 2. Walk the track layout with as many top drivers in your region, and drivers of all driving styles and platforms (FWD,RWD,AWD, etc.) 3. If anything, you can always learn something from everyone, even how NOT to drive a course (i.e.- bad drivers, or bad habits) |
on the topic of bars.
if it doesn't triangulate it doesnt stiffen enough to make it worth the $$ http://www.yarisworld.com/forums/sho...28&postcount=1
#18 | |
Apexing Egg!!
| Body kits from Thailand | cali yaris | Micro Image | 175 | 04-23-2010 12:42 PM |
| GTSPEC under bracing installed/pics | blacksandiegovitz | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 29 | 05-01-2009 10:45 AM |
| GTSPEC Bracing.... | Fluid Motorsports | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 17 | 11-11-2008 07:48 PM |
| under bracing/ bars | pinoypizzaboy | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 4 | 11-10-2008 09:09 PM |
