Spoiler painted for $25
got it painted now time to install....shhhh cost me $25 to paint :) again no instructions whats the easiest way to install? stick on with tape then drill or hold it up mark spots then drill and stick on?[ATTACH][ATTACH]IMAG0003.jpg[/ATTACH][/ATTACH]
very nice :) hold the wing up snug, use a sharpie or a punch to mark the drill points, remove wing, drill holes, insert grommets, use stickytape for wing, stick into place, bolt it up.
if it's an ebay wing you'll HAVE to buy longer bolts. the ones supplied are too short. i just did this for a YW member a couple days ago :)
i recommend either using a step bit or 3 different bits
1/8 inch for pilot then 1/4 for mid then final size, what is it, 12mm?
its from yaris universe so it looks like the screws might be a bit to short. thanks for the help though
can you shoot a photo of the profided hardware?
wow, just 25 dollars to get it painted? Im having a headache now about mine..
yeah $25 a guy owed me a favor and happen to ahve his own paint booth so i jsut had to buy the paint.[ATTACH]IMAG0005.jpg[/ATTACH]
those bushings will crush outwards when compressed?
they look metal!
they are metel. do I need to get new ones? from what i can figure washer goes on screw, screw goes on spoiler, bushing comes from inside the body panel for the screw to screw into and holds it in place. is that not right? its what came with it so thats the best i could tell.
#10 | |
ill see if i can find that setting its a cheap old digital
i cant get a non-fuzzy shot of them, but they are metel and wide on one end with groovs to lock it into place. the other end without the enlarged ring around it is threaded about halfway down
ok hmmm... just be careful with the hole drilling, gotta get those bushings TIGHT in place
believe me drilling a hole in my car is going to be extremely hard for me to do and will be double checked about 100 times before that drill gets close to it starting out small and working up in the sizes
where in georgia are you? north georgia? if i end up in chatt soon i'm more than willing to drill the holes for you :)
middle west, in columbus.
![]() ![]() ![]() Drives: ings 09 Yaris 3 Door LiftBack Join Date: Mar 2009
you gonna sleep with the spoiler, right
REAL JDM ings+1 Full Body Kit…REAL JDM C-One Spoiler…Retrofit Projector Headlight…Kiddo 6-pots BBK…CE 28N J-Time Attack…Bride Ergo II Racing Seat…Personal Steering Wheel…Work Bell Quick Release…Dealer Option Sun Roof…JDM RS LED Side Mirror…JDM RS Taillight…C-One Oil Cap…C-One Radiator Cap…TRD Iridium Racing Spark Plug…Tom's Fuel Map Controller…Blitz throttle controller…GReddy Informeter Touch…MR Suspension…TRD Rear Sway Bar…MR C-Pillar Bar…GTspec Front Strut Bar & Rear Strut Bar…AFE Intake…WR Header…Nitto Mid-Pipe…Greddy Ti-C axleback…Goodridge SS Brake Line… To do: Supercharger… |
MetalShark
Drives: 2008 Yaris LB Join Date: Oct 2008
If those nut sleeves are like I've used, put a locking star washer and nut on the bolt with the star washer between the sleeve and the nut. Screw them into the insert and hold the sleeve and nut stationary with an end wrench while tightening the bolt to expand the sleeve below the panel. I'd slip in some RTV when installing these and put the bolts in with blue locktite to keep all water out.,
Absolutely red, Drawtite hitch, CAI, Insulated Header, Amsoil 5w-30, Mag-drain plug, Red-Line MT-90 tranny oil, Scotch-Guard, Window Tint, Dash rug, Custom short throw shifter, Lowered OEM arm rest, Super-Turbo muffler/w chrome slash cut tip., TRD rear sway bar, sticky pads, front shock tower bar, RS grill badge, VVT-i emblems, Second tire set from Tirerack.com, DISABLED DAY TIME RUNNING LIGHTS, platform- style locking custom bike rack. 86K miles so far. 5 years use now on ceramic wrapped insulated stainless-steel header. |
| DIY Sedan Spoiler Install | Kaotic Lazagna | DIY / Maintenance / Service | 36 | 01-19-2020 11:35 PM |
| BNIB: White painted oem lip spoiler | mikenacarato | Items for Sale by private party | 6 | 12-19-2008 12:30 AM |
| RS SPOILER ... SAD | aznbabiegrlx0x0 | Cosmetic Modifications (Exterior/Interior) | 42 | 09-28-2007 09:49 PM |
| RS Spoiler (Yes i tried to search it!!) | hasher22 | Cosmetic Modifications (Exterior/Interior) | 2 | 08-23-2007 11:02 PM |
| Rally style spoiler in white for sale!! | cheukli | Items for Sale by private party | 11 | 07-18-2007 09:02 AM |
