Old 05-22-2009, 02:52 PM   #1
By the way, I have an extra set of brackets.
If someone doesn't have to tools, or doesn't understand the grinding process to move the HU deeper, so the trim piece will fit with wider HUs, I can modify the set that I have and ship it to you in exchange for your set.
CTScott is offline
Old 05-22-2009, 08:12 PM   #2
Adriaan
In between cities
Adriaan's Avatar
Drives: 2006 yaris ce
Still doesn't work due to the cover it the same size as the pionner unit. Because of pionner stupid din size i had to trim the double din metra brackets so it could fit. Guess i'm stuck with the 200mm opening. Unless i change the cover pocket to an open version. But then i'll have items out in the open which i don't like.
Adriaan is offline
Old 05-23-2009, 04:13 AM   #3
IsLNdbOi
IsLNdbOi's Avatar
How do you grind the positioning stubs? Will a dremel w/ a sanding head do it?
All I have to do is grind down all of the positioning stubs on the sides of the bracket that face the head unit, right?
IsLNdbOi is offline
Old 05-23-2009, 06:48 AM   #4
I used a file to remove the stubs. Dremel will work as well. The metal is very soft and easy to remove.
Yes, all you have to do is eliminate all 6 stubs on the HU side of the bracket.
WeeYari is offline
Dash destroyed in electrical fire. purpleminx General Yaris / Vitz Discussion 79 06-12-2009 03:53 PM
Double Din 180mm Trim Bezel esyres In Car Entertainment + Electronics (audio / video / alarm) 19 03-19-2009 09:01 PM
[Recovered] Group Buy for Australia #1 (Badges) harveyjai Australia 9 12-13-2008 03:59 PM
