Old 05-22-2009, 03:14 PM   #1
jkuchta
Drives: 2007 Yaris hatch (red)
Make sure there are no leaks between the TB and the intake manifold.
Did you use the stock yaris TB gasket (that O-ring with the small brass screen)?
Once you get the idle screw fixed you'll be in good shape.
The fact that the TB came from an auto car won't make a differance.
jkuchta is offline   Reply With Quote
Old 05-22-2009, 03:29 PM   #2
Yoda
Yoda's Avatar
Drives: 2008 Black Sedan
Once you get the idle screw fixed you'll be in god shape.
yea i did use the o ring. Gonna try and dyno it on Monday cause i don't really notice a diff really
I an attempt to figure this out i sarted reading
http://www.etimago.com/yaris/repairm...%20Control.pdf
search 2103
1.8L Engine Swap, Possible? Yaris T-Sport Performance Modifications 4 05-06-2007 06:57 PM
swap for 2zz-ge???? yarisTOONR82 Performance Modifications 12 03-23-2007 07:15 PM
