Old 05-22-2009, 06:43 PM   #1
aeipee13
DKDC
aeipee13's Avatar
Drives: Yarlet
You could run your rear with a higher offset than the front. Say no more than 2-10mm difference between the front and rear. I know looks-wise it may not be what you want but it will help the car rotate better. I think if you combine everything said earlier with the "reverse staggered offset" (i don't know if there is a term for that setup) you could achieve what you are after.
I'm planning on running the "reverse staggered offset" once I get wheels sorted so if you don't get around to it I will let you know how it feels. My suspension is stock and I will be running only a 23mm rear sway bar,stock suspension , 15x7 et37 or 16x7 et40 on Falken RT615s 205/50/15 or 16. Once Tamago finishes his hub spacers I was going to run the 13mm in the front and the 10mm in the rear.
aeipee13 is offline   Reply With Quote
Old 05-22-2009, 09:04 PM   #2
Tamago
Tamago's Avatar
Drives: UZJ100
the car is already 25mm skinnier in the rear. IMO making the rear wider (more stable) would be a better start. put that swaybar to work for you!
Old 05-23-2009, 01:49 AM   #3
aeipee13
DKDC
aeipee13's Avatar
Drives: Yarlet
For sure your suggestion is a better start for him. But for me I think the car rotates fairly well stock for an FF. I just wanted to mess around with different offsets after spending a few years reading other Yaris owner's feedback with different suspension/tire/wheel/bar setups. I wanted the car to be tighter in the rear but rotate easier. The sway should handle a lot of the roll while the wider front helps the rear rotate. Right?
No one else has tried it yet so i figure what the hell, give it a shot?
I went with these wheels. http://www.yarisworld.com/forums/showthread.php?t=15883 It turns out you can only get them in Japan according to Simon. I kind of believe him because when i looked them up to check if they were real and not really good knock offs, i couldn't find this size listed. After seeing them in person, they're real.
