Old 05-25-2009, 04:38 PM   #1
Taiyaki
アキバ製
Taiyaki's Avatar
hey where is good places to tap my relay?
I bought a SPST relay. I was planning on tapping the "30" straight to the battery, "85" of course grounded, "87" to the power window red wire, and "86" to the Ignition wire.
Oh! where is the ignition wire? or could I just hook it up to any power that turns off/on when the car is off/on?
also do i need a fuse in between if im going to hook up straight to the battery?
Old 05-25-2009, 09:37 PM   #2
You can tap the ignition switch harness. White is accessory or pink is ignition.
Definitely use a fuse for the battery tap. Size it per the power requirements of the power window system.
Electrical System Upgrade Advice sqcomp In Car Entertainment + Electronics (audio / video / alarm) 6 03-23-2016 01:15 AM
Possible Revolutionary Power Source...Aquygen nsmitchell General Yaris / Vitz Discussion 7 06-20-2007 07:32 AM
POWER WINDOW POWER SOURCE IN DOOR PANEL? mrrock DIY / Maintenance / Service 5 03-21-2007 06:27 PM
Need Help - Electrical (finding Power) Ayka DIY / Maintenance / Service 7 10-12-2006 11:51 AM
