Originally Posted by seth_man
P0171 is a lean condition. which means your getting not enough fuel or un-metered air into the engine after the mass air flow sensor. double check everything you touched make sure hoses are connected and not broken and i would pull that TB off again and check the gasket. just pulling the battery to clear the code wont repair the problem.
have you been following the TB threads? If there really is a problem, then the code will come back, if it simply needs to re-learn the stock Tb again, then it wont. No need to rip everything apart again when there is no certainty there is another problem.
One step at a time.
