アキバ製
Drives: 09' White LB, Celica GTS Join Date: Apr 2009
Airbag light is on
hello,
Well after installing my power windows the airbag light is on. When installing them I did blow a few fuses and maybe did somthing? First off what is the light mean? and is there a way to fix it? without taking it to toyota. |
Be very careful when dealing with DIY fixes for airbags because if you dont know exactly what you are doing you may set it off, the resulting explosive energy could be lethal.
![]() ![]() Drives: 08' HB Join Date: Oct 2008
You may have popped a airbag wire clip out.
0 - 60 in 3 shifts
アキバ製
so just take it to toyota?
You can make it display the SRS DTC's by flashes of the SRS light by jumping CG to TC on the OBD connector. Power off, jump the pins, power on and watch the flashes. Count the short flashes between longer pauses and look up the DTC in the service manual.
srs.jpg |
| srs / airbag light after head unit install? | KwonSau | In Car Entertainment + Electronics (audio / video / alarm) | 7 | 12-24-2008 02:04 AM |
| DIY:Day time running light Disabled with stock fog light remain function | summergxz | DIY / Maintenance / Service | 12 | 09-26-2007 10:42 AM |
| "Airbag" center console light on 07 Sedan with side airbags | atebit | In Car Entertainment + Electronics (audio / video / alarm) | 5 | 11-10-2006 06:10 PM |
