![]() ![]() Drives: 07 Yaris 3DR Join Date: Apr 2007
I CANNOT get the front strut nut off
I'm trying to install my TEIN springs. I got the back done easy peezy. I've got everything off the front necessary to access the front strut bolts with the alan key inside and 17mm nut.
I CANNOT use a box wrench to turn it, it just starts to stip the upper part of the bolt. I CANNOT use a ratchet with a socket to loosten it because I need the alan key to hold the centre from moving. How the bloody hell do I get these nuts off? The spring install guide makes it sound easy peezy but that just is NOT happening. Does anyone know if a socket with a hexagonal outside (instead of completely round) exists? You know then I could use the socket and use a large like 19 or 21mm box wrench to turn the socket... OR anyone have any other teniques? Thanks |
remove the top panels plastic and steel , wiper's then use a impact gun
electric or air powered , also make sure you are turnning the nut counter clock wise
I dont think you understand what I mean, I've already done all that.
But I got them off I went and bought some better vice grips. |
Small cars are a big deal
Drives: 2007 Yaris Liftback Join Date: Feb 2006
You need a 17mm off-set wrench. It's the only good way to get that nut off.
17mm wrench and the correct allen wrench, then it will come off.
Subcompact Culture: The Small car blog |
![]() ![]() ![]() Drives: Yaris Join Date: Apr 2009
If you are trying too remove the first nut on the strut , do it while there is upward pressure on the strut ,
ie with wheel on and sitting on the ground or with jack under wheel hub , this takes some of the pressure of that nut . if you are talking about the secound nut use spring compressor to take up spring pressure , of nut . |
What thirtynine said. I used a offset wrench and a allen key. I used a small pipe on the end of the allen key to hold it in place and a long handle offset box wrench. Came off with a little effort without having to remove the cowl.
Drives: yw calls me douche and racist. Join Date: Aug 2007
ok thanks guys.
I eventually got them off by using some vice grips with a 17mm socket and a alan wrench... I have another problem now though. I'll make a different thread though as it's a totally different problem. I'll have to pick me up some wrenches. |
^ correct answers, offset box end wrench FTW, or air tools.
| Tanabe Front Strut Bar | Benggolf2 | Performance Modifications | 57 | 08-15-2014 02:41 AM |
| Which front bar do you prefer? Strut or Sway? | TitaniumBarbell | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 17 | 10-16-2009 11:52 AM |
| Any difference on Tanabe front Strut Bar VS Unknown ebay Strut Bar? | TitaniumBarbell | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 4 | 04-07-2009 06:58 PM |
| 2006-2007 Yaris 4 Door Front Strut Bar AEM/DC Sport | KenAEM | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 6 | 02-22-2007 11:08 AM |
| C-ONE Front Strut Tower Bar - Installed & Impressions (Pics to Come) | bigsky2 | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 20 | 01-10-2007 06:53 PM |
